Originally posted by Brad Simpson
The offsets are 20 and 22.5 so I shouldn't need spacers, right? The rims are 8x18 and 9.5x18. So the question is: with the wider tires, will I have clearance/rubbing issues?
From Robs previous post;
"These non-spec offsets also limit tire size. Not so much of a factor in the front, although a 13 front may cause rubbing with 255s or larger with the wheel turned to one extreme or the other. In the rear, let's face one simple fact: E34 M5s do not have enough tire (tire sizes are always a factory-made compromise, balancing performance, mpg, cost, and noise - performance usually suffers). Using the BMW E34 M5 17x9 or E39 M5 18x9.5 rears (both et22 offset) allows the use of 275-section tire, usually without spacers (due to eccentricity of the subframe mounting, some cars may require 5mm spacers to avoid slight contact with the inner fender liner). When using the E38's rear wheel (et25), you will most likely need a spacer no matter what. Under ideal circumstances, the spacer would be avoided - I can feel the difference in the rear with vs. without the spacer.
There is also the issue of wheel bearing wear. BMW wheel bearings are sloppy under the best of circumstances (already responsible for degraded brake feel, suspension sloppiness/shudder, and play that causes other components to wear faster). Chaning the load point is not doing these bearings any favors."
So, some E39 wheels are 13mm front offset.
If the E39 M5 wheels are 22mm offset at the rear, then as above, you might need 5mm spacers.
What are the fronts, `cause I thought they were 13mm, and need spacers.
Ivan.
