Old 23rd August 2003, 18:54   #1
Speeder
Garage: 95 525i Silver
Whump-Whump Sound In Back When Parking
I only notice this weird, soft, low, whump-whump sound coming from the rear when making type slow parking lot turns. I assume it's a problem with the limitted slip diff but I was dissapointed that an experienced BMW had no suggestion but to change fluid which did nothing.
The diff seems to work fine. It's the softness of the sound that gives me wishful thinkin that it could be something stupid or easy to fix. Is there something that can be done from the rear cover? If it requires dropping the rear end, I might just live with it. It can be a little embarassing when I have passengers.
Speeder is offline
Old 24th August 2003, 08:50   #2
mblaster
mblaster's Avatar
Garage: 91 m5 black
Is your clutch in, out , or feathering?
mblaster is offline
Old 24th August 2003, 21:26   #3
g boyd
g boyd's Avatar
Garage: 1992 Macaoblue
Q when they changed the diff oil what was it like ? if it was clean forget about it .
I would put the car on a free wheel ramp to check,
Turn the wheels
I am sure it will be the rear brake disc rubbing on the backing plate or the handbrake shoes come lose on one side,
Check the basics first.
Graham
Enthusiasm Overcomes Adhesion
g boyd is offline
Old 25th August 2003, 15:21   #4
ECM4
ECM4's Avatar
Garage: E34 M5 3.8 6sp Kashmir Biege
This sounds a bit like the noise that my 328 touring makes from time to time during slow parking manouvers. It sounds a bit like someone thumping the floor.
I'm convinced its the LSD and I'm not really too concerned. There's some bushes around the front and rear of the diff which I was going to have a look at, maybe replace them, but like I say I'm not that bothered.
I had an Isuzu Trooper with an LSD (it needed it!) in the back axle. It used to thump at times (normally coming out of junctions) but it was totally normal acording to the handbook and a big sticker on the dash.
ECM4 is offline
Old 26th August 2003, 06:27   #5
mblaster
mblaster's Avatar
Garage: 91 m5 black
The reason I asked about the clutch is that my car makes the same noise but it goes away when I push in the clutch. My mechanic doesn't seem to worried...so what, me worry?
mblaster is offline
Old 28th August 2003, 01:10   #6
Steven
Steven's Avatar
Garage: 1990 M5
Pushing on the clutch makes the noise go away. Sounds like something under load. I would check the drive line just to be absolutely sure. It may be the early stages of a center bearing failure. I don't know for sure, but I would rather have total piece of mind. Just grasping at straws.
Steven
1990 M5
2003 Land Rover Discovery II SE7
Steven is offline
Old 28th August 2003, 08:33   #7
mblaster
mblaster's Avatar
Garage: 91 m5 black
Maybe this is dumb, but where and what is the center bearing ?
mblaster is offline
Old 31st August 2003, 01:51   #8
Prutser
Prutser's Avatar
Garage: Diamantschwarz-metallic 1992 BMW E34 M5 3.8
Send a message via ICQ to Prutser
The low, whump-whump sound is really just the LSD. That's how these (rather primitive) things sound when you make sharp slow turns. There are better diff designs (like the ones in the Hummer), but in cars they only ever use LSD's. Nothing to feel embarassed about.
Prutser is offline
Old 31st August 2003, 03:01   #9
mblaster
mblaster's Avatar
Garage: 91 m5 black
The guy's that work on my car said it was the LSD too. And not to worry everything was good.
mblaster is offline
Old 4th September 2003, 16:11   #10
ECM4
ECM4's Avatar
Just had a run in the wife's 328 and its worse than I thought!
I think I'll change the oil. It's just had an inspection by BMW but I wonder if they changed the stuff!
I've got Castrol SAF-XJ in the M5 and I may give it a go in the 328.
By the way you can now get this LSD synthetic gear oil from Castrol in 5 litre containers. Castrol Classic Oils decant it from the normal 25 litre containers. It costs a fortune, £65.......
http://www.castrolclassicoils.co.uk/
ECM4 is offline
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 61 7th January 2009 11:06
New option on E60 (from autospies). Gene E60 M5 and E61 M5 Touring Discussion 7 23rd January 2003 18:09
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
More engine sound at idle please Tom E39 M5 and E52 Z8 Discussion 11 22nd June 2000 06:02
Page generated in 0.23583 seconds with 11 queries
