Old 16th August 2003, 19:56   #1
jack880
Garage: Macau blue E34 M5 (3.6 5spd)
Urgent advice needed!
Please can someone give me some advice - my 1990 3.6l recently failed its MOT due to needing both rear shocks replacing (leaking). I haven't yet replaced them (my car is booked in for tuesday but I needed to drive somewhere this weekend), and have just noticed that one side of the car is lower than it should be (about 20mm ish). Could this be to do with the shocks? I would have thought that the shocks would only affect the bounciness of the car, rather than the height when not driving.
Does anyone know what the problem is likely to be?
Thanks!
Jack
1990 3.6 Macau Blue
jack880 is offline
Old 16th August 2003, 21:13   #2
Steven
Steven's Avatar
Garage: 1990 M5
The SLS rear suspension is basicly hydraulic, so it's always under pressure. If you have a leak, the size of the leak will depend on how fast the car starts to sag. You should also see it come to the proper ride height when the car is started. Good luck, those shocks can be pricey.
Steven
1990 M5
2003 Land Rover Discovery II SE7
Steven is offline
Old 17th August 2003, 02:24   #3
mblaster
mblaster's Avatar
Garage: 91 m5 black
I kept my sls shocks that I'm not using any more. They are both OK. Make me an offer I can't refuse.
mblaster is offline
Old 17th August 2003, 14:29   #4
jack880
mblaster - thanks, but I'd probably prefer to get new ones, and as my car isn't driveable at the moment I need to get it sorted out as soon as possible... But how much would you want to sell them for?
Steven - thanks for that. The car does rise up when the engine is started, but not to the proper height (on one side). It seems that one wheel (the one where the car is lower) may be very slightly further in than the other one. When I jacked the back of the car up I could see that the wheel had been rubbing on the back face of the wheel arch - any idea if the leaking shock could in any way draw the wheel inwards?? Or maybe its just my measuring techniques.....
Also it may be my imagination but I think I can hear a hissing sound - is that the system trying to raise the pressure in the leaking shock? Although I can't see any fluid dripping out or anything. Are they definately hydraulic rather than pneumatic?
Thanks again
Jack
1990 3.6 Macau Blue
jack880 is offline
Old 18th August 2003, 04:51   #5
Steven
Steven's Avatar
Garage: 1990 M5
jack880,
Sorry to hear about all the other problems. The SLS is definately hydraulic, because it functions off the power steering fluid. That's why you must use CHF 7.1(if I recall correctly) and nothing else.
You shouldn't hear a hissing sound. Could it be the fuel pump? Check the power steering fluid and see if it's low, the SLS may have gotten air bound, highly unlikely but you never know.
As far as the rubbing dilema, I would suspect something bent of worn out. Or, is it just the wheel rubs when the car begins to sag a bit? Probably ought to inspect the rear suspension.
Hope I could help.
Steven
1990 M5
Steven is offline
Old 18th August 2003, 13:22   #6
jack880
Thanks Steven. The car's due for its annual check which I understand to involve checking all the fluid levels, so that might clear up some issues. And I'll get them to check the suspension when replacing the shocks anyway.
Thanks for your opinion, much appreciated.
Jack
1990 3.6 Macau Blue
jack880 is offline
Old 19th August 2003, 07:13   #7
mblaster
mblaster's Avatar
Garage: 91 m5 black
You might want to think about ditching the SLS system. I got rid of mine and the car rides and handles much better. No BS.
mblaster is offline
M5 Purchase. Advice needed. vadim E39 M5 and E52 Z8 Discussion 11 29th September 2003 15:28
ADVICE NEEDED: I have $10,000 banker415 E39 M5 and E52 Z8 Discussion 32 20th June 2003 20:46
Urgent help needed with fusebox! Dallas Spikes E39 M5 and E52 Z8 Discussion 7 20th April 2002 20:00
Advice needed for Hartge 19" Wheels m5monster E39 M5 and E52 Z8 Discussion 9 26th October 2001 06:56
Advice needed before long road trip Vince E39 M5 and E52 Z8 Discussion 4 20th June 2001 00:22
Page generated in 0.12579 seconds with 11 queries
