Old 13th August 2003, 12:41   #1
IvanDias
IvanDias's Avatar
Where is the speaker that makes the "Gong" Noise ???
Hi,
Where is the speaker that makes the "GONG" noise that signals an OBC error.
I need to unplug or disable it temporarily.
My hearing is not too good one side, so I can`t home in on where the sound comes from. (no stereo detection)
Thanks,
Ivan.
IvanDias is offline
Old 13th August 2003, 15:35   #2
e34m5uk
Garage: Sterling Silver 1993 3.8
Hi Ivan,
The speaker that makes the "gong" noise is in the trim panel under the dashboard on the drivers side. If you look just above the pedals you should see that there are a number of holes in the trim (this is how the sound gets through the trim). You will need to remove the kick panel to the right to be able to remove the lower trim panel.
Hope that helps.
Miles
1993 3.8
e34m5uk is offline
Old 16th August 2003, 04:36   #3
Steven
Steven's Avatar
Garage: 1990 M5
I put a strip of duct tape over it, now it's much more tolerable. Just remember you probably won't hear at speed so check the cluster every so often.
Steven
Steven is offline
rattle/knock noise from rear solved! Jacob Lee E39 M5 and E52 Z8 Discussion 4 14th April 2009 21:08
Annoying noise from inside dash ??? Where/What ???? IvanDias E34 M5 Discussion 10 17th March 2003 12:35
Fixed R sway bar bracket but it still makes noise TriflowM5+M3 E39 M5 and E52 Z8 Discussion 2 28th October 2002 21:31
"VANOS noise" in front of driver at idle ? Tom E39 M5 and E52 Z8 Discussion 1 14th April 2000 03:23
Page generated in 0.12383 seconds with 11 queries
