Old 27th February 2003, 17:05   #1
IvanDias
IvanDias's Avatar
Annoying noise from inside dash ??? Where/What ????
Guys,
I`ve a horrible noise, it started out as just a light whirr, as if a fan bearing was worn (like when a computer cpu fan gets old), then it changed to a bad whirring when cold, then light after a few minutes, but now it`s a horrible low pitched grinding whirr constantly.
The noise starts anywhere from immediately the car is started up to about 5-10 seconds after the engine starts, and goes off sometimes a little later (5-30 mins), sometimes never until the engine is killed after parking.
I have a RHD car, so the passenger sits on the left. The noise is coming from in front of the passenger, above the glovebox, there`s a recess for storage on top of the dash, with the speaker to the left and the grill for air (?) in the middle of the dash.
It`s coming from around or under the storage recess, more towards the windscreen than the glovebox front.
I`d thought windscreen adjustment motor, but that`s on the right hand side by the steering wheel on a RHD isn`t it, so it can`t be that ??
Turning the fans on from off-1-2-3-4 makes no change, nor does pressing the button to make the air recycle inside the car.
The air-con is non-functional on my car, but pressing the button doesn`t make the noise change anyway.
Doesn`t sounds like an earthing issue with the speaker, it`s not soming from there.
Finally, the noise does change in pitch ever so slightly as you drive along, but it is random +/- 10% maximum, and is not related directly to engine rpm or actual speed in a gear.
Any ideas before I start to pull the dash apart ????
Is there anything windscreen wiper related on the left hand side of the engine bay of a RHD car?
HELP !! It`s doing my head in !!!
IvanDias is offline
Old 27th February 2003, 20:32   #2
ilundber
ilundber's Avatar
Garage: 1991 M5 Lagunengrunmetallic and 2001 M5 Le Mans Blue
Hello IvanDiaz,
I don't know if there is something from the wipers in front of the pasenger side of a RHD-car, but my guess would be that one of the small electrical motors that control the air direction (to the windscreen, to the vent in the dash etc) is gone. I have something of the same problem. Sometimes it makes a very loud noise approx 30 sec after I have started the engine and it keeps making the noise for about 30 - 60 sec.
Taking the dash out took about an hour of work, even for a beginner like me. I did that last summer. The only thing that you need to do in order to make life simple is to dis-connect the four big electrical connectors on the left hand side under the dash( on a LHD car) and the connectors to the temperature control at the centre and the wiring going under the central console. That way you won't have to cut all the wireing loose from the dash as I did out of ignorance.
You have to take down the cover of the A-colons in order to be able to loosen the screews there and you need to undo the two bolts under the dash.
There are, if I remember correctly, four motors under the dash that you then can investigate.
Putting the dash back is also quite simple.
Regards, Ilundber
ilundber is offline
Old 27th February 2003, 21:40   #3
JP
JP's Avatar
Garage: E34///M5-mugello
First tought whas : whiper-arm-tensioner broke/stuck aswhell .(but rhd ? )
Noise really resonates , so could be , stuck heatingv. ,direktional....aso...,
They do work independed off fan setting .
try feeling if the commanded heat goes the chosen side ,
and only that ! (< ^ >) .
that way , no need for dis and asembling ( for diagnosis ) .
JP.
JP is offline
Old 28th February 2003, 07:28   #4
de Witt
de Witt's Avatar
Garage: 1988 M5 (x2) 1991 M5 2008 M5
Send a message via AIM to de Witt
If it is not changing pitch or stoping when you change the air from 1-2-3-4, then I would rule out a fan bearing. Usually when a fan bearing is blown, a lower speed will produce a much slower/louder noise and a higher speed will reduce the faster/noise or the noise will go away. That is from my experience.
Is it making a quick chirping noise? RPM shouldnt have an effect on the fan bearing.
I guess BMW just swapped sides on an RHD. I have to think what might be over there....
{o,o}
|)__)
The E28 M5 FAQ
The E34 M5 FAQ
The E24 M6/M635CSi FAQ
de Witt is offline
Old 28th February 2003, 11:42   #5
jack880
Garage: Macau blue E34 M5 (3.6 5spd)
hello
I don't know about the M5, but I had a RHD 320i and the wiper motor was in front of the passenger. I read somewhere (probably this messageboard) that the wiper motor on the M5 winds up when the car is started to hold the wipers down in case you decide to do 150mph... Maybe yours isn't stopping and keeps trying to tighten itself?? My car makes a whirring noise from the dash after it's started that stops after 5 to 10 seconds. Dunno if any of this is any use, probably nothing you don't already know!
jack880 is offline
Old 28th February 2003, 12:07   #6
IvanDias
IvanDias's Avatar
That`s what I suspected, the magical M5 wiper pressure motor, but I understood that this was on the drivers side only, which is why I asked you clever guys out there if there was anything else I`d be checking before before the dash comes off.
Thanks, please feel free to continue if anyones had this problem.
I might just post a little video or soundclip of it. Would this help?
Ivan
IvanDias is offline
Old 28th February 2003, 15:55   #7
Donati
Garage: 2 x '91 M5, Sebring Grey
Send a message via ICQ to Donati
Soundclip could help.
You are talking about "blown fan-bearings noise", did you check the cooling fan located under/behind the DME/ECU?
In my LHD car its located on the right side of the car, just under the box that holds the DME/ECU.
I dont know if this is moved to the left side of a RHD car?
This fan runs as soon as you turn the ignition on, before the engine is started.
It makes a sound exactly like a computer PSU cooling fan, and
at first i thought it sounded like it was coming from somewhere behind the glovebox.
I noticed this fan when i was changing my ecu chip, and since you have also an aftermarket chip, maybe you have noticed this fans location also?
Mvh. Finn Donati
Donati is offline
Old 3rd March 2003, 01:05   #8
mikek
Garage: 530i
Ivan,
Could it be the cooling system inline electric water pump that sits on the passenger side of the car. It is used in extreme circumstances to pump the engines coolant at a higher rate when the ordinary water pump cannot cope???
Regards
E30 M3 (Sold 1997)
E34 M5 3.6 (sold 6th March 2003)
E36 M3 3.0 (sold 6th November 2004)
E39 530i Touring
mikek is offline
Old 3rd March 2003, 11:20   #9
IvanDias
IvanDias's Avatar
I`ll get the garage to check, but I`d hope not, it had a new water pump 4000 miles ago.
Ivan.
IvanDias is offline
Old 15th March 2003, 11:48   #10
Alan Archer
Alan Archer's Avatar
Garage: M5 3.8 Diamond Black
I would surgest isolating fuses to see which circuit the noise
belongs to before going the whole Hog with the dash senario !!!
Afterall, you can live without the wiper tensioner so long as you stay below 140 Ivan !!
Alan.
Alan Archer is offline
rattle/knock noise from rear solved! Jacob Lee E39 M5 and E52 Z8 Discussion 4 14th April 2009 21:08
Annoying arm rest noise GreekM5 E39 M5 and E52 Z8 Discussion 2 9th July 2002 07:16
Page generated in 0.18709 seconds with 11 queries
