Old 28th December 2002, 16:25   #1
KAMIKADZE
KAMIKADZE's Avatar
Garage: '94 338is
Send a message via ICQ to KAMIKADZE
Clutch And Flywheel
Hi there
First to ask - Can I put a flywheel from 3.6 on 3.8 engine and what is the difference
Please post me info about clutch and flywheel upgrade on 3.8 M5 engine post links if you have
*** BMW '94 338is ***
KAMIKADZE is offline
Old 28th December 2002, 21:46   #2
jrturbo
Garage: E34 M5 1995 Daytona violet
hi there
the 3.8 uses a dual mass flywheel which is very heavy by comparison to a solid flywheel, in addition a solid flywheey can be lightened even further by machining material away to make it lighter, this will improve throttle response and make the car accelerate quicker in the lower gears provided you have the traction available.
i am not sure but i believe that the 3.6 uses a solid a flywheel and both engines use the same clutch kit.
regards
Joe Rubido
jrturbo is offline
Dinan Flywheel help please. Stevus E39 M5 and E52 Z8 Discussion 14 29th November 2003 06:26
New Dinan Clutch 'n Flywheel Assembly for M5?? gra8fuldd ed E39 M5 and E52 Z8 Discussion 18 9th October 2003 22:27
A Clutch Tutorial greg E39 M5 and E52 Z8 Discussion 10 31st October 2000 18:48
aftermarket clutch and flywheel??? AndyMenard E39 M5 and E52 Z8 Discussion 0 20th October 2000 04:01
Happy again -- new clutch in my M5 Wolf359 E39 M5 and E52 Z8 Discussion 0 2nd August 2000 02:48
Page generated in 0.08609 seconds with 11 queries
