Hi there
I beleive the wiring set up with the factory amp is as follows
Black- Earth
Red 12 v live - connected to ignition switch
Yellow - 12v ilumination - connected to dash lights
The four wires are the speaker outputs L & R channels, the amp in the boot, amplifies the from the speaker signal.
If you fit a more modern unit, you may have to locate a permanent live to connect to the radio so it doesnt loose its memry presets.
I personally would recommend you fit a Kenwood mask unit, where the fascia revolves when you switch the ignition and leaves an innocent looking black panel + no hassle in remebering to carry the front panel.
Regards
Joe Rubido
