Old 16th October 2002, 01:00   #1
Steve Mac
Steve Mac's Avatar
Garage: 2001 M5 Le mans
how much do you put in???
Just an interest
I was wondering what psi you guys put in your tyres
I have ///M Parallels and put in 38psi but wondering what you guys put in??
I know the reccomended but experience counts for more IMHO
Steve Mac
Steve Mac is offline
Old 16th October 2002, 04:11   #2
Alan Yeung
Garage: 1990 M5 Sebring Grey
40 psi in my 235/45/17's
Alan Yeung is offline
Old 16th October 2002, 10:24   #3
Mmm-Five
I put 2.9 bar in the front and 3.0 bar in the rear
Or about 39 psi in the front and 41 psi in the rear.
I have played around a little by going 2 or 3 psi up and down, but didn't notice any difference that I could say was definitely pressure related rather than purely in my head (i.e. changed it so it must be better/worse, etc.).
I have noticed that lower pressures help in the wet though, whereas on a wet airfield I prefer higher pressures as it helps to slide the car round for a bit of gooning
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is offline
Old 16th October 2002, 18:26   #4
IvanDias
IvanDias's Avatar
I go pretty much halfway between the loaded and unloaded figures in the dorwell plate.
I must admit I`ve played with the exact unloaded and then the exact loaded figures, and day to day use I can`t tell.
However, if the cars loaded with people, then I notice a lot of squealing from the fronts when loaded, eg accelerating around hard corners with the suspnsion compressed and the pressures are for the unloaded settings. Same bend with just me and it`s perfect, so BMW obviously put the two pressure values in for a reason.
I also noticed huge squeals from my right rear under pulling out from junctions, turned out to be a screw in the tyre deflating it to around 22psi rather than the monster 44psi odd it should have. Check your tyres regularly !! And the Oil. Water. Petrol. Belts. Spare. Lights. Brake fluid. Air Con. Door hinges. Sunroof. LOL.
Ivan.
IvanDias is offline
Old 20th October 2002, 18:05   #5
mikek
Garage: 530i
M5 40 PSI 235/45/17 and 255/40/17
M3 40 PSI 235/40/17
Regards
E30 M3 (Sold 1997)
E34 M5 3.6 (sold 6th March 2003)
E36 M3 3.0 (sold 6th November 2004)
E39 530i Touring
mikek is offline
Old 23rd October 2002, 14:02   #6
Malcolm
Garage: Brilliant Red 1990 E34 M5 also Henna Red E30 M3
What you put in depends also on the ambient air temperature, loading and driving conditions etc., as well as your individual driving characteristics and tyre brand.
Personally -- I have Continental ContiSportContacts (great tyre for me!) and use 35psi in the front - 235/45ZR17 and 32psi in the rear - 255/40ZR17. BUT, the ambient temp where I drive is 35C++ , so as already mentioned, check tyre pressure & wear regularly, just as you do the coolant, oil, windscreen cleaner and fuel.
Also get the wheels aligned more often than just when you fit new tyres. It helps with handling and improves tread life.
Malcolm is offline
I just put down $$$$ for GT3 spring delivery JP Schnitzer Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 10 6th August 2003 19:04
A-hole gas attendant put 87 octane!! fais2000 E39 M5 and E52 Z8 Discussion 12 15th November 2001 08:19
Got 3.45 diff put on. Here's my review. tfung E39 M5 and E52 Z8 Discussion 4 9th November 2001 02:37
How can I put pictures in the message ? MTY Feedback / Discussion about www.bmwm5.com and the Messageboard 0 11th December 2000 10:03
Page generated in 0.14406 seconds with 11 queries
