Old 15th October 2002, 07:28   #1
Bmxbikergtss
Bmxbikergtss's Avatar
Garage: 94 E34 540i w/ DINAN orient blue
Send a message via AIM to Bmxbikergtss
Rear end Problems
ok the rear of the car squeeks when i go in reverse. sounds like the breaks are rubbing. I only notice it when i first start up the car and back it up.
Coming Soon: E60 ///M5
Alpine white/black perforated/aluminum
2003 ///M5 Sterling grey/ Silverstone
1994 Dinan 540 orient blue/tan(sold)
Bmxbikergtss is offline
Old 16th October 2002, 01:06   #2
Kurt Ramsden
Garage: e34 3.8 M5
Do you use your handbrake ? If so, it could be binding a little.
It could be an exhaust clearance problem also. Or any number of other things I guess....
Kurt Ramsden is offline
Old 16th October 2002, 11:43   #3
jrturbo
Garage: E34 M5 1995 Daytona violet
hi there
The bmw range with discs fitted at the rear is notorious for squeaks from the handbrake shoes that run inside the discs.
Most E34 will produce a squeak from the handbrake shoes if you rock the car with handbrake on, if the squeak you hear when going in reverse is the same, then the problem could be the handbrake adjusted too tight.
On other hand it could be you pads squealing in reverse, which would requiere removing the all the pads, cleaning them with emery paper and chanfering the edges.
Hope this helps
Regards
Joe Rubido
jrturbo is offline
new E60 rear end group buy! alpinadvl E60 M5 and E61 M5 Touring Discussion 1 15th February 2003 23:16
Any problems with rear lights? Ashok Arora E39 M5 and E52 Z8 Discussion 1 15th December 2002 20:23
A Deawoo hit my rear end yesterday!! robret witelus E39 M5 and E52 Z8 Discussion 5 19th February 2002 09:04
Flywheel and lower rear end... Thoughts? bobpommer E39 M5 and E52 Z8 Discussion 1 1st June 2001 01:52
Page generated in 0.11116 seconds with 11 queries
