Old 30th September 2002, 19:40   #1
rcalvin
Garage: 1994 M5 Touring Daytona Violet
Lightweight flywheel?
Just wondering if there are any aftermarket lightweight flywheels for the 93 3.8L M5 Touring? I have seen all kinds of aftermarket products for the M3 but very little for the M5.
Rick
93 M5 Touring 3.8L 5-Speed
rcalvin is offline
Old 1st October 2002, 15:05   #2
jrturbo
Garage: E34 M5 1995 Daytona violet
Hi there
I am not aware of anyone having lightweight flywheels off shelf for the M5 engines, although a competent machine shop could make one.
I have heard of some people in some cases fitting the flywheel from the earlier M5 which wasnt a dual mass unit, and it should be possible to lighten it further, but the problem your are going to encounter is that most engine machine shops will requiere a crank to bolt the flywheel on to, so that they can rebalance the flywheel after lightening it.
beware of anyone who offers to lighten your flywheel without rebalacing it, it will introduce vibrations which will shorten the life of your engine components ie crank, conrods, etc.
I would be interested to hear about your findings on the matter.
regards
Joe Rubido
jrturbo is offline
Old 1st October 2002, 16:31   #3
rcalvin
Flywheel Rattle & Gear Oil
Yes, I have heard that the 3.6L M5 flywheel, which is lighter, can be used.
However, I have also been told that the 3.6L flywheel installed on the 3.8L might "rattle" in nuetral. I don't know if I would be comfortable hearing that.
But, I have also been told that by using LubriMoly, instead of the factory gear oil, the rattle could be eliminated.
Any of you guys fix rattling flywheels by using a different type of gear oil.
Rick
rcalvin is offline
Old 1st October 2002, 23:02   #4
dmenheere
dmenheere's Avatar
Garage: 91 M5 Red
Hi Rick,
It is not the flywheel that rattles but the transmission. With the lighter flywheel I believe there is less dampening of the input shaft and the gears in the transmission will rattle. There is no damage done by this.
cheers,
Dave
1991 M5 3.6L
dmenheere is offline
Old 14th October 2002, 06:32   #5
rcalvin
Thanks for the clarification Dave.
Also, do you know if the 3.6L M5 flywheel is interchangeable with the 3.8L M5 dual mass flywheel?
Rick
rcalvin is offline
Old 14th October 2002, 15:58   #6
dmenheere
dmenheere's Avatar
Garage: 91 M5 Red
Hi Rick,
The 3.6L flywheel will bolt to the 3.8L engine. The respective clutches may be different but a 3.6L flywheel with a 3.6L clutch will work. I will check tonight whether the part numbers for the clutch changed. The 3.6L flywheel weights ~12 lbs versus ~20 lbs for the 3.8L.
Dave
1991 M5 3.6L
Old 15th October 2002, 21:55   #7
dmenheere
dmenheere's Avatar
Garage: 91 M5 Red
Hi Rick, please check the link for info on someone who has already done it. I just remembered I had been though this discussion already. At the bottom of the thread he explains how he used the 3.6 flywheel and cltuch on the 3.8 engine.
cheers,
Dave
http://www.bmwm5.com/vbulletin/showt...threadid=20133
1991 M5 3.6L
Dinan Flywheel help please. Stevus E39 M5 and E52 Z8 Discussion 14 29th November 2003 06:26
TECH: Roundel got me in a tizzy--VAC's lightweight flywheel!! Teutonaddict E39 M5 and E52 Z8 Discussion 7 22nd September 2003 17:46
Upgraded flywheel? gsfent E39 M5 and E52 Z8 Discussion 1 7th February 2003 00:31
All right: who bought the Dinan lightweight flywheels ON SALE! Teutonaddict E39 M5 and E52 Z8 Discussion 10 12th December 2002 13:29
Dinan Lightweight Flywheels available! tfung E39 M5 and E52 Z8 Discussion 7 28th September 2001 22:11
Page generated in 0.11919 seconds with 11 queries
