Old 23rd September 2002, 17:56   #1
dronfieldm
Garage: 1995 BMW M5 3.8 6 Speed - Avus Blue
Rev Counter Operation
People,
How does the rev counter collect the engine speed.......
I nipped out to the local shops this lunch time and all was OK. When I drove back to work, I noticed that the rev counter wasn't reading correctly. I was travelling up a slight incline, at I guess 1800 rpm, but the gauge showed 200 rpm. When I parked up I revved the car to, say 2000 rpm, and the rev counter moved up from 200 rpm to 800 rpm.
This is very weird !! Car drives fine. I'll have to see what happens when I drive home. It was fine this morning.
In the "olden days" they used to feed from pulses from the coil didn't they ?
Any ideas ?
Maybe last nights earthquake has affected it !!!!
Many Thanks
Mark
1995 3.8 6 speed - gone, but not forgotten.
1999 Land Rover Discovery Td5 ES
dronfieldm is offline
Old 24th September 2002, 01:04   #2
Alan Archer
Alan Archer's Avatar
Garage: M5 3.8 Diamond Black
hmm,
two options, gauge or control,
Firstly do the usual test....ignition off,press&hold right
hand check control button, turn on ignition, let display
test function, finally, the instruments should test.
Both speedo & rpm gauges should rise to vertical, around
85mph & 4000rpm, then return to zero.
Does this work ?
The second cause of the fault could be faulty/dead batteries
on the rear of the instrument pack...these batteries are soldered
in place but are replaceable.
I've only ever had them go on E28's but E34's are just the same,
and the results of dead batteries on E28's include no temp gauge
and erratic revs/economy read out.
Alan Archer.
Alan Archer is offline
Old 24th September 2002, 12:04   #3
dronfieldm
Thanks for your help Alan.
It was just as I hoped. Drove home last night and all is fine. It has been fine since. What can I say ? I'll just have to keep an eye on it.
I am definately not going mad, I did see it !!!!
Mark
Problems to look out for when buying M5's BarryP E34 M5 Discussion 29 17th September 2002 18:52
pre-purchase inspection paolo E34 M5 Discussion 8 28th April 2002 23:46
NAV setup info re: version...i.e. 3-1/30, seems to be timestamp, not rev version Jacob Lee E39 M5 and E52 Z8 Discussion 3 1st February 2002 00:37
Inspection I & II checklist please IvanDias E34 M5 Discussion 2 2nd November 2001 15:31
tach readings v. rev limiter Trent D E34 M5 Discussion 0 26th January 2001 17:12
Page generated in 0.10280 seconds with 11 queries
