Compression Test Results - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 19th January 2013, 14:35   #1
AseanAero
AseanAero's Avatar
Garage: 1990 E34 M5 Shwarz II
Delving into Taffy's M5 oil loss problem on GA25331 we took a compression test on his engine and got the following results
GA25331 is a UK spec high compression engine. Comp numbers with the engine warm (standing for 1.5hrs while we had our usual long lunch) and throttle closed (I forgot to open the throttle)
Cyls 1 to 6 - 180, 180, 180, 180, 180, 190
Then we took the compression on GA25324 (my M5) which has low compression tropical version 9.2:1
Cyls 1 to 6 - 175, 170, 165, 170, 170, 175
What's a normal compression reading for a normal and low compression version of the S38B36 ?
It looks like GA25331s oil leak is a combination of a poor sealing oil filler cap and dipstick and a stripped acorn nut on the cam cover
Tony, long term Aussie expat in Jakarta Indonesia (going troppo)
1990 E34 M5 S38B36 Schwarz II, 57,000kms, Tropical version, full Nappa leather interior, Superchip , staggered TS 235/45 ZR17 , 255/40 ZR17 Toyo T1R (good tyres) mods planned : exhaust system. Restoration items : Reinstall the SLS, interior tidy up, bodywork : repair small dents and re-spray in the original color
1995 E34 530i 5 speed Daytona Violet 154,000kms , 18" wheels , mods planned: EXHAUST : used M5 rear muffler (done), X pipe (pending) and removal of front mufflers (done), slotted + drilled discs, chip, Momo steering wheel, 235/45 ZR18 , 255/40 ZR18 Toyo T1R - my daily driver and a car that I can play with and modify.
AseanAero is offline   Reply With Quote
Old 19th January 2013, 15:56   #2
BlueBiturbo
BlueBiturbo's Avatar
Garage: 1990 BMW E34 M5
Finally found what we think is the cause of the oil leak ! YEAH !
Gotta order oil cap from the internet and wait 10 days
Welcome to coconut island
It is said that if you line up all the cars in the world end to end, someone would be stupid enough to try and pass them.
BlueBiturbo is offline   Reply With Quote
Old 19th January 2013, 16:31   #3
uk_bm
Garage: Avus blue E34 M5 3.8
I changed the oil cap on mine when investigating oil consumption. Made no difference.
The system should be negative pressure there, it could be there is some splash (what I thought before buying a cap) but it was a red herring in my case,
Incidentally I got my cap from the BMW dealer... Stupidly cheap price, as it sometimes the case with BMW parts.
uk_bm is offline   Reply With Quote
Old 19th January 2013, 16:57   #4
BlueBiturbo
Mine was definitely leaking from there.
I wiped the surrounding area clean yesterday, it is oily again today after 6500 rpm run.
Old 19th January 2013, 17:02   #5
uk_bm
I hope it is that... Would be a great, easy, fix.
When I remove my cap (quite often for top ups) there is oil presence underneath the sealing faces.
Old 19th January 2013, 17:08   #6
BlueBiturbo
My fingers are crossed
Old 19th January 2013, 20:17   #7
Nikosx
Nikosx's Avatar
Garage: 91 Brilliantrot, 92 Schwarz, 91 Schwarz
It wouldn't just be damp there at the amount of oil loss you're experiencing.
Pull the intake elbow off the plenum. Is it oily inside the plenum?
Nikosx is offline   Reply With Quote
Old 20th January 2013, 03:04   #8
Roland H
Garage: cars are terrible investments
There aren't any real numbers that you should be striving for, since all compression tests are different. Density Altitude plays a huge effect in compression testing. Consistency across cylinders is more important. I usually say each cylinder within 5-10%. The testing gauge is also important, it's good to use an Aviation Grade tester vs the one you get at the tool store, as many sold at the tool stores aren't built to the same, if any, standards.
Leakdown tests are much better for determining engine health though.
Roland H is offline   Reply With Quote
Old 20th January 2013, 17:50   #9
AseanAero
AseanAero's Avatar
No significant quantities of oil in the plenum, just a very slight thin film of oil
Old 21st January 2013, 00:50   #10
BlueBiturbo
Turns out that I DO HAVE a new spare oil filler cap !
Just installed it today. It is VERY tight seal.
I will drive it hard tomorrow and see the difference.
Compression Test results of my E39 M5 M5 Jed E39 M5 and E52 Z8 Discussion 8 21st July 2012 18:08
Compression test results - input needed AtlantaDan E34 M5 Discussion 7 14th August 2010 03:33
Compression test. 9's and 10's Black M5 E60 M5 and E61 M5 Touring Discussion 9 11th August 2009 20:25
Compression and Leak-Down Results jfdturbo E39 M5 and E52 Z8 Discussion 9 29th November 2007 07:13
Tech: Engine compression is 1:11 - why is the compression test spec 1:12 - 1:14? DavidS E39 M5 and E52 Z8 Discussion 2 3rd June 2003 21:02
