Old 8th September 2002, 23:37   #1
ian hall
Garage: 95 M5 Avus Blue
Coolant leak
My car is leaking coolant from somewhere at the back of the engine.It is really hard to see where from,water appears on the sound deadening and then runs everywhere!!
I thought it might be the heater matrix,this is usually confirmed by a smell from the heater-which i do not have.The leak did seem to get worse when the heater was on.Is this a coincidence or is there some sort of valve that lets coolant into the heater when it is turned on?
Apart from this the car has been very reliable!
Ian
P.S Car is a 94 3.8
ian hall is offline
Old 9th September 2002, 00:21   #2
M5 powered
Garage: M5 limited edition (02/50) Rosso Red
I can tell you exactly what this is as it happened to me three weeks ago! It's the aux water pump seal (used on startup before the main one kicks in) which has failed. For some stupid reason (only known to BMW) they put a bleed valve on this which tends to fail when the rubber perishes over time. It's located by the matrix and hence why some think this £1000 part has failed. As the water system is under pressure the coolant goes everywhere and makes it difficult to locate.
The cost for the pump is around 60-80 pounds and is a generic 5 series part. Also check all the pipes around that area and look for cracks.
Regards
M5 powered
1995 M5 Limited Edition (02/50)Rosso Red
Pilot Sport 2 Rubber
Valentine One With Conceal
Twin Head LRC100 IR Jammer System
Origin Blue B2 GPS
M5 powered is offline
Old 9th September 2002, 12:02   #3
dronfieldm
Garage: 1995 BMW M5 3.8 6 Speed - Avus Blue
Sounds like the culprit. I had the same problem on my E32 735i some years ago. I did have the inside of the windscreen misting up more often as well.............my M5 has not been affected yet !!!!
All the best
1995 3.8 6 speed - gone, but not forgotten.
1999 Land Rover Discovery Td5 ES
dronfieldm is offline
Winter Protection - Antifreeze & Similar? IvanDias E34 M5 Discussion 25 16th February 2006 20:16
Glitter in my coolant overflow Steven E34 M5 Discussion 15 8th January 2003 19:24
Oil leak mickle E34 M5 Discussion 4 15th December 2002 21:10
Does everyone has add air pressure valve on top of their coolant tank karlcchen E34 M5 Discussion 4 27th December 2001 00:33
Oil leak RSouthern E39 M5 and E52 Z8 Discussion 8 20th December 2000 19:12
Page generated in 0.08798 seconds with 11 queries
