Old 5th September 2002, 18:20   #1
DrSakke
DrSakke's Avatar
OBC test???
Hello again!!
One question...
I read a thread about the obc test(Turning on the ignition while pushing down the button on the right on the instrument cluster)
As I understood ALL the meters should hit the max with this test.
In my car every meter hit the max marker except that rev counter showed 4000 revs/min and the spedo read 140km/h(approx. 87 mph)
What does this mean??
(at the moment my baby`s at a BMW garage for waterpump and windshield change) original waterpump at 133000 kms(83k miles)
Waiting for new rear subframe bushings and new clutch in the near future.
sakke
DrSakke is offline
Old 5th September 2002, 19:43   #2
IvanDias
IvanDias's Avatar
I was told that all the needles went around to max. They do not. Most go full travel, but the speedo and the rev counter go to about halfway.
I have tried it on the 535 and the M5, plus others have reported it only going this far.
I think that the generalisation of "press the button and do the ignition and all the dials move about" has been been misinterpreted as to how exactly they move about.
Ivan.
IvanDias is offline
Old 5th September 2002, 20:29   #3
de Witt
de Witt's Avatar
Garage: 1988 M5 (x2) 1991 M5 2008 M5
Send a message via AIM to de Witt
Ivan is correct. The Speedo and Rev needles should only go about halfway. I have done this to my E34 M5 and 525i.
{o,o}
|)__)
The E28 M5 FAQ
The E34 M5 FAQ
The E24 M6/M635CSi FAQ
de Witt is offline
Old 6th September 2002, 11:54   #4
StormMaster
Garage: 1993 M5 (Daytona Violet)
I second what Ivan has said. The results Sakke reported are identical to those I get in my own car when performing this test. Full scale needle deflection on the speedometer and tachometer is not to be expected -- at least not on any of the cars I am familiar with.
I think that some of this misunderstanding may have arisen from a photo that was posted here a month or two ago which initially appeared to be a shot of the instrument cluster (needles pegged) taken at a very high rate of speed. This turned into a test-related debate when several members questioned discrepancies in the photo -- most notably having to do with the fact that the water temp and oil temp were nowhere near operating temperature. Actually, I just found the thread HERE.
Perhaps some of the older models tested a bit differently?
Chuck
1993 Euro ///M5 (Daytona Violet)
StormMaster is offline
Old 11th September 2002, 15:07   #5
DrSakke
DrSakke's Avatar
Thanks for sorting that out.
(My baby now has a new windscreen and waterpump)
Best regards
Sakke
DrSakke is offline
Results of our Powerchip side-by-side test greg E39 M5 and E52 Z8 Discussion 43 1st May 2003 01:41
OBC Menu scottiedavies M5 E39 and E60 tips & tricks 4 19th December 2002 06:00
OBC Menu scottiedavies E39 M5 and E52 Z8 Discussion 3 4th November 2002 17:59
DME Fault Codes ? Kurt Ramsden E34 M5 Discussion 8 20th June 2002 19:20
Page generated in 0.12544 seconds with 11 queries
