My E34 M5 stroker 4.1L 361whp - BMW M5 Forum and M6 Forums
Like Tree5Likes
Old 1st December 2012, 12:36   #1
h0pen
Garage: E34 M5 S38b41 361whp/414wnm Diamantscwhartz
Have build a stroker engine in my m5 with Electromotive TecGT enginemanagment.
It got 361Whp/414Wnm
Pics in this post: bimmers.no • Se emne - E34 M5 S38b41 361whp/414wnm
I come back with more info later
Sorry for bad english
h0pen is offline   Reply With Quote
Old 1st December 2012, 17:48   #2
davidoli
Hi and welcome to the forum , H0pen .
What a fabulous build ........ I've never seen more than a 3.9 stroker before .
What compression ratio are the pistons and are you using a 96 mm stroke with a 95mm bore ?
Who built your crank ?
What ignition system / ECU are you using ?
What are your experiences of the car with this engine fitted ?
D
91 Sebring 3.6 | E28 UK RHD M5 | E34 UK RHD 3.8 | E34 M5 Touring | E24 M635CSi UK RHD
www.classicmdautos.co.uk
davidoli is offline   Reply With Quote
Old 2nd December 2012, 01:18   #3
BlueBiturbo
BlueBiturbo's Avatar
Garage: 1990 BMW E34 M5
My guess is that You are using PPM Australia 4.2 crank ?
It is said that if you line up all the cars in the world end to end, someone would be stupid enough to try and pass them.
BlueBiturbo is offline   Reply With Quote
Old 2nd December 2012, 08:28   #4
davidoli
I don't believe many owners have completed a build using PPM's kit yet .
This crank doesn't look like one of their's !
Old 2nd December 2012, 15:05   #5
AseanAero
AseanAero's Avatar
Garage: 1990 E34 M5 Shwarz II
Is a 4.1 or 4.2 litre stroker is going too far ?
A standard 3.6 has a piston speed of 20.16 metres per second at 7,200rpm, 86mm stroke
3.8 litre is 21.6 at 7,200 (is the rpm limit on the 38B38 the same or lower than the B36 ?), 90mm stroke
This particular 4.1L is 23 m/s at 7,200rpm, 96mm stroke.
4.2 litre 23.5 metres per second at 7,200 , 98mm stroke ???
If you took a 4.2L to 8,000 that would be 26.1 metres per second (assuming a race engine build with a higher rpm limit), formula 1 engines are doing about 27m/s. A race 4.2L would have a life of only a few thousand km at those piston speeds ?
A good discussion here
Engine & fuel engineering - maximum piston speed?
Tony, long term Aussie expat in Jakarta Indonesia (going troppo)
1990 E34 M5 S38B36 Schwarz II, 57,000kms, Tropical version, full Nappa leather interior, Superchip , staggered TS 235/45 ZR17 , 255/40 ZR17 Toyo T1R (good tyres) mods planned : exhaust system. Restoration items : Reinstall the SLS, interior tidy up, bodywork : repair small dents and re-spray in the original color
1995 E34 530i 5 speed Daytona Violet 154,000kms , 18" wheels , mods planned: EXHAUST : used M5 rear muffler (done), X pipe (pending) and removal of front mufflers (done), slotted + drilled discs, chip, Momo steering wheel, 235/45 ZR18 , 255/40 ZR18 Toyo T1R - my daily driver and a car that I can play with and modify.
AseanAero is online now   Reply With Quote
Old 2nd December 2012, 15:39   #6
AseanAero
AseanAero's Avatar
Nice engine hOpen
Old 2nd December 2012, 18:27   #7
davidoli
Is 4.2 Litre straight 6 going too far ?
Time will tell .............
Old 2nd December 2012, 19:20   #8
AseanAero
AseanAero's Avatar
Porsche GTS RS 4.0 is 22.11 m/s about the same as the S38B38 , it gets away with 8,250 with a short 80.4mm stroke
Old 2nd December 2012, 20:11   #9
h0pen
D
Thats right.
Crank is coustom made in sweden.
Ignition/ecu is Electromotive TecGT Total Engine Control TEC GT - Electromotive Engine Controls
Comp is 11,5:1
Havet got oportunity to try the car yet because of the winter.
The Following 2 Users Say Thank You to h0pen For This Useful Post:
corneredge (3rd December 2012), davidoli (2nd December 2012)
Old 5th December 2012, 16:17   #10
GoneAgain
GoneAgain's Avatar
Garage: 1988 Sebring Grey.....reborn
Jaguar did alright with it for a while.
GoneAgain is offline   Reply With Quote
M6 Stroker duhawks E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 22 12th March 2012 19:40
Video: Nooelle BMW M6 stroker (Dinan stroker) vs Evotech RS6 BiTurbo Evotech 700 HP vs Ferrari 575 Maranello Gustav E60 M5 and E61 M5 Touring Discussion 14 27th August 2009 10:34
Video: Noolle BMW M6 stroker (Dinan stroker) vs Evotech RS6 BiTurbo Evotech 700 HP vs Ferrari 575 Maranello Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 3 19th August 2009 03:01
45 minutes discussion with Dinan on the V10 stroker engine + news that there will be a stroker Dinan M3 V8! Gustav E60 M5 and E61 M5 Touring Discussion 24 30th December 2008 13:12
E34 M5 Dinan 3.9 stroker FS: fugginfazt Parts / Other For Sale or Wanted 1 28th May 2006 19:54
