24th July 2012, 12:45
#1
Stupid little problem:)
Gents,
I'm almost ashaned to ask this on the forum but:
My dash says "washer fluid low". I checked the sensor itself and it reads a perfect zero ohm resistance when magnet-floater is closed. I shortcutted the 2 wires and still the dash says washer fluid low.
I even stripped the wires behind the connectors and shortcutted there but no results.
The wires go together with some other sensor wires and the horn through the fireshield below/behind the DME box.
Now the question:
What's the best way to proceed?
Cheers
E34 M5 Touring, March '95, 100% original, Memory seats, Electric roof, 6-speed, 280.000 km, Fjord Grau.
Renewed: Front suspension and disks, Springs and EDC's, Steeringbox and linkages, Crankshaft bearings, bigend bearings, Ignition coils and guides, clutch, rims (m-paralell) and tyres, All vacuum hoses, Waterpump, thermostat, black powerflex front and rear.
Buildsheet / Touring registry
