10th August 2012, 11:14
#169
Thoughts
I applaud OPs attempts at establishing a baseline and then making a modification and remeasuring.
I would have been more interested in his findings if the story had gone differently.
Ie, after the first Dyno run, he should have realized from the AFR that his engine was not running properly. This means that something in the system, whether it was TPS, air meter, IAT, O2 sensors, coolant sensors, vacuum leaks (whatever) is suspect, and in fact can not be relied on. Essentially he did not have a stock car as claimed, he had a broken car, without a diagnosis. Until that is fixed, I don't see how any reliability or reproduction of baseline can be counted on. He may well have components that are transiently working, and then not working. This issue to me pretty much negates any findings he's made, he's got to fix his car first and take out the variable of a broken and hence unreliable system.
Is there ANYone (other than OP maybe) that believes his baseline run reflects expected AFR for an S38 with a healthy engine management system with all components working properly?
A second consideration is that even in the absence of a reliable engine management system, the actual condition of air pump and AC compressor are not necessarily representative of properly functioning devices. It may be that they are damaged and did in fact present a much higher than common parasitic drag to the system. In that case, OP's findings might be applicable only to his car, or people with similarly broken/worn or damaged air pumps and compressors.
I'd love to see this energetic new member fix his car, get a baseline that represents an S38 running properly, show a dyno run where the AFR is where it should be to confirm all is well with his engine management, and THEN cut the belt to see the difference. On the same day, after the cars fluids are properly warmed up in gearbox, diff etc....
You can't have it both ways, if OP wants to trust his first Dyno shop of choice, then the message from their AFR should have been "go fix your car"
Ie, their WB is probably accurate, his car is not functioning properly, or in my mind reliably.
Interesting thread. Insomnia sucks.
