Idle Control Valve - Where is it ? - BMW M5 Forum and M6 Forums
Old 4th July 2012, 02:19   #1
AseanAero
AseanAero's Avatar
Garage: 1990 E34 M5 Shwarz II
I'm new to the M5 and I have an idle problem when the air conditioning is turned on , the idle will jump to 2,500rpm , when the air conditioning off the idle is 900-1000rpm. Some searching online indicates it could be a dirty or blocked ICV but where is it ?
I've searched all over the internet and can't find any photos or diagrams.
AseanAero is online now   Reply With Quote
Old 4th July 2012, 04:37   #2
91Champagne
Garage: '91 M5 Macao on Champagne
It is under the throttle bodies/air accumulator.
Pop off the airbox and air accumulator and you will see the sea of vacuum lines running around down there. While you are cleaning out the ICV, be sure to inspect those vacuum lines. They are often very worn and cracking.
91Champagne is offline   Reply With Quote
Old 4th July 2012, 05:27   #3
AseanAero
AseanAero's Avatar
Thanks Champagne, the car has been sitting in storage for a while so I'm expecting to find some hoses that need replacing as well
Old 30th July 2012, 09:52   #4
AseanAero
AseanAero's Avatar
http://mmm-five.net/Articles/files/E...esOverhaul.pdf
I found this online which gives very clear step by step instructions for removing the intake plenum which maybe useful to other new owners (this is old hat to the veterans )
P.S. One of the things I don't like about working on BMWs so far is the endless plastic clips and tabs, some of which were designed by Mr Rubic I think (of Rubic's cube fame). They seem to have their own special techniques required to get them out without damage.
Old 30th July 2012, 10:33   #5
Sub8
Garage: LMB E39 M5, Swartz E34 M5, Red 528i Touring, R33 GTR V-spec, FocusRS, UK Scooby
Blocked or dirty ICV would result in low idle speed. The flare with AC activation is more likely to be a low AC system pressure; the ECU is expecting an AC load to arrive when you turn it on. The ECU opens the ICV valve more (its allready open to control your base non-AC idle speed) to allow more air into the engine to offset the higher load due to AC. With low AC system pressure no additional AC load actually arrives and you get an engine flare.
Does your AC blow cold air?
Sub8 is online now   Reply With Quote
Old 30th July 2012, 11:08   #6
AseanAero
AseanAero's Avatar
Thanks Sub8 , that makes sense.
When they filled the air conditioning on saturday they used 3 small cans of refrigerant , I didn't notice the system pressure , when I checked online later on Saturday night I noticed that a full charge should be in the range of 1.2 to 1.4kg. I think the cans of refrigerant would be half that.
The air conditioning belt is also suspect so that needs to be changed , I had a few belt squeals this morning.
The AC is blowing ice cubes when it's on , very cold.
I've been using the AC at cruise speeds and when the vehicle is moving as I can control the rpm when the M5 is in gear to normal levels. It's idling in traffic that's the problem.
I'm going to have to use the local BMW dealer , these local shops are a waste of time.
Old 30th July 2012, 15:45   #7
uk_bm
Garage: Avus blue E34 M5 3.8
My local independant is good for this kind of thing... Weighs the stuff out and in.
Regarding low pressure/mass, I am pretty certain that the low pressure switch that protects the pump also stops the idle offset coming on. If you have cold air... Leave it alone.
uk_bm is offline   Reply With Quote
Old 1st September 2012, 16:54   #8
AseanAero
AseanAero's Avatar
It was the air conditioner belt
The M5 came out of a 4 day check up in the dealer , the air conditioning problem (2,000 to 2,500rpm at idle with air cond on) turned out to be the wrong size belt. It didn't make any noises for 7 weeks , it was only the last week that it started squealing , belt was too long and not the right profile , it was too wide and not seating into the pulley properly.
I now have fully functioning air cond which is great as today was a hot one , I had to turn the air cond right down this evening as it was too cold
Old 1st September 2012, 17:00   #9
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II 93 M5 3.8 Sterling Silber
Belt? Not sure i see how the belt would effect idle speed, the ac load isn't that great. I had the same problem with ac and idle speed and it was a bad throttle switch.
mottati is online now   Reply With Quote
Old 1st September 2012, 19:06   #10
Sub8
Could be as I described above. With a loose belt the engine doesn`t see the full AC load.
Throttle switch is another possibility. A very important and `underestimated` component in terms of healthy engine operation.
E39 For Sale: E39 Idle Control Valve rated ///M Parts / Other For Sale or Wanted 0 15th November 2011 20:44
faulty idle control valve? GradjeD E34 M5 Discussion 6 15th September 2010 23:59
Idle Control Valve Help 215m3 E34 M5 Discussion 2 23rd May 2010 17:11
e39 m5 idle control valve SirSparky E39 M5 and E52 Z8 Discussion 14 27th December 2009 18:57
Anyone cleaned idle control valve? Roadmovie E39 M5 and E52 Z8 Discussion 4 6th August 2008 00:18
