WOT Surge - BMW M5 Forum and M6 Forums
Old 2nd July 2012, 04:03   #1
Protouring442
Garage: Calypso Red 1993 M5
WOT Surge
OK. I have a '93 M5 that has a surge as the engine climbs through the revs at WOT (wide open throttle). Let off the throttle just a tad and it accelerates smoothly.
Any ideas where I might start in a search as to what might be wrong?
Thanks!
Bill
Protouring442 is offline   Reply With Quote
Old 2nd July 2012, 07:38   #2
Flanker35M
Garage: BMW M5 E34 Sonderlackierung(490)
S!
Depending on if you have the S38B36 or S38B38 engine check the function of the resonance flap. It has an effect on acceleration. The B36 makes the test upon starting, with B38 you need to rev the engine 4k+ rpm or put a small dot of grease on the stopper and take a faster drive to see if the actuator has moved and touched the grease. If it does not work then vacuum hoses need a thorough inspection, look at the Resonance Flap thread for example, has good tips and even parts numbers you might require. BMW is picky about the vacuum system from what I have noticed.
Then check all the venting tubes for the oil system, there are 3 coming to the plenum. 2 thicker and 1 thinner, connecting to or near the or separation bowl under the plenum. If you have the plenum removed, check the idle motor and it's tubes as well. Clean the idle motor well as it can be soothy thus causing rough idle.
The normal checks are of course air filter, spark plugs, fuel filter etc. MAF can be inspected if it is dirty and the rubber tube going from MAF to Plenum if it has cracks in it, with age they can get a bit brittle.
I would start with these checks and sure that the more experienced gurus here will chime in as well They know their stuff
Flanker35M is offline   Reply With Quote
Old 2nd July 2012, 10:28   #3
Fordkoppie
Fordkoppie's Avatar
Garage: E34 3.6 M5 Glacier Blue, E34 540i/6 Individual, RS 5000 Ford Sapphire, 323i e30 2dr, 1965 MK1 Cortina GT
Damper pully could be loose/has moved
Fordkoppie is offline   Reply With Quote
Old 2nd July 2012, 14:35   #4
Protouring442
As soon as I have the time, I shall pull the plenum and clean/inspect everything. This makes sense to me as, now that I think about it, I have noticed that, when first started, the idle will hunt. It bounces up/down until I raise the rpms by hitting the gas, or after I drive off.
Thanks!
Shiny Side Up!
Bill
Check out the latest installment of my current project: www.WilliamKElliott.com
Profits surge at BMW Ashok Arora Off Topic Forum 0 4th May 2011 14:10
Irratic idle surge Kodiak E28 M5 Discussion 1 7th May 2003 04:37
The 4000 rpm surge Pepsmeister E34 M5 Discussion 15 26th October 2002 15:20
Surge - Need Help Please sscaro E34 M5 Discussion 3 27th May 2002 23:16
E28 idle surge/hesitation Ralph Seilius E28 M5 Discussion 2 7th March 2001 16:00
