Adjustable Cam Gear Sprocket - BMW M5 Forum and M6 Forums
Like Tree21Likes
Old 13th June 2012, 03:29   #1
pspassos
pspassos's Avatar
Garage: 95 M5 3.8
Anyone knows of any adjustable cam gear sprocket for the S38B38?
I found this one, from VAC Motorsport in the US.... quite expensive.... I searcher the forum but just found some information about the Dinan ones (not adjustable) and the OEM ones as well...
This is the ones I found: http://store.vacmotorsports.com/vac-...-set-p366.aspx
'95 3.8 6speed ///M5
You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you rotect it like it's your family, then you drive it like you stole it.
pspassos is offline   Reply With Quote
Old 14th June 2012, 09:00   #2
First e28 M5
First e28 M5's Avatar
Garage: E24 M6's
Whats wrong if you slot your existing ones at the machine shop ? Then you can use the camshaft dial indicator to adjust the timing etc...
Just a thought
Anri
__________________________________________________ _________________________
- It is super fun to build your own custom car the way you want it and like it.
- E24 M6 1988. Shwartz/Tan Original condition. Daily driver, keeper, Dinan suspension, Dinan adjustable sway bars, Evo S14 A100 cam gear, TMS chip, 360mm 6pot front, BBS 17x9,5 BBS E26 Magnesium Race wheels wrapped 255's.
- E24 M6 1988 Shwartz/Grey Collectible for shows 100% all original unrestored, keeper..
- E24 M6 1988 Shwarts/Lotus For Sale E24 M6 http://euroclassicmotors.com/galleries/bmwm6e24.html.
- E24 M6 1988 Royal Blue/Lotus white S85-B50 Restoration in proses.
- E24 M6 1988 Shwartz/Recaro S38-B36 3.6 goal is ~52/48 weight distribution at around 2800 pounds. My Track car for Vintage Racing !
- E30 M3 1990 Euro B38 3.8 goal is ~52/48 at ~2800 pounds.
- E53 X5 3.0 2003 Wife's car.
- E31 840Ci 1997 Black/Black, CSI exterior.
First e28 M5 is offline   Reply With Quote
The Following User Says Thank You to First e28 M5 For This Useful Post:
pspassos (15th June 2012)
Old 15th June 2012, 01:42   #3
pspassos
pspassos's Avatar
Garage: 95 M5 3.8
I have had this idea already too my friend, thanks for your comment.... it would really be much much cheaper, BUT I do not have anyone here in Brazil that I can trust to do this job correctly, without compromising the sprockets.... I have already spent so much money in the car with the engine rebuild, head work, standalone, shorter diff, etc etc, that I do not think that now would be the time to try to save some money like this... maybe finding some other supplier, but not trying to do it by myself....
Old 15th June 2012, 08:18   #4
davidoli
Hi Paulo ,
I've got a couple of S38B38 cam sprockets and I will see if I can get our engineers to machine them for you .
D
91 Sebring 3.6 | E28 UK RHD M5 | E34 UK RHD 3.8 | E34 M5 Touring | E24 M635CSi UK RHD
www.classicmdautos.co.uk
davidoli is offline   Reply With Quote
Old 15th June 2012, 08:49   #5
First e28 M5
Garage: E24 M6's
Hi,
That should not be a problem for most of machine shops who offer engine service such as head work, valve job etc...
Anri
Old 15th June 2012, 14:50   #6
pspassos
pspassos's Avatar
Garage: 95 M5 3.8
Depending on the price and process of making it, it would BE perfect David!
Anri, to males it is really easy... To make it properly not as much... I cannot put it on a simple press to have it fixes and work on it... It is necesary to first build a fixation toll to hold it by the center not to damage it...
Sorry for my poor technical english...
Old 15th June 2012, 15:17   #7
pspassos
pspassos's Avatar
Garage: 95 M5 3.8
Another question for you gurus... Will the S14 Evo ones fit the S38B38? I am talking about 11311311781 part number... And I also found the 11311308513 part number as well...
I have doubts because I know S14 and S38B36 can interchange it, but the camshaft sensor on B38 is on a different position...
Old 15th June 2012, 16:48   #8
First e28 M5
Garage: E24 M6's
Hi,
In your particular case with aftermarket performance camshaft to fit S14 EVO A100 does not make absolute no sense ! You need adjustable so you can do fine tuning.
You need to be careful who is doing your camshaft degree because if you dont trust machine shop to slot your cam gears job for students! I am scared to think of who is going to degree your camshaft...
The S14 EVO A100 was discovered back in early 89-90 (i dont want to even go in details by whom because its not proven etc..) to be used in S38-B35, used only on the exhaust site.
Their are 2 choices either retard or advance by half a notch. If advance the exhaust you are increasing the mid range. If retard you are shifting it to upper power band. Recently I changed head gasket on M88/3 and advanced the exhaust cam gear by half a notch(slot the cam gear). On my daily driver I have that Retard for the upper rpm band.
The B38 A108 E108 was upgrade used in S38-B36 by advancing the Intake by 2 degree and retarding the exhaust by 2 degree being from stock B36 A110 E110. Great upgrade with TMS chip and open free flow exhaust.
Hope this will explain the A100 EVO S14 why is not a choice for you.
Anri
The Following 2 Users Say Thank You to First e28 M5 For This Useful Post:
davidoli (15th June 2012), pspassos (16th June 2012)
Old 18th June 2012, 12:41   #9
MatheusS50
Garage: E36 black
Originally Posted by First e28 M5 View Post
Hi,
Anri
Hi..
Iīm the engine builder of Passosīs engine.
From what you say here, is very easy to see that you never saw in your life a EVO sprocket.
The option to choose that is not due the OEM timming fixed, but itīs already sloted, just fixed OEM timming by a removable woodruf key.
Our doubtīs is not due timming, but fitment (example: pick up rotor for cam sensor that is used in B38, but in B36 and S14 is distributor rotor) .
By the way, i believe you never used it before (considering your words that you said here), so, cannot help us.
Regarding the machine shop, i donīt know in your country, but machining cylinder head and cylinders, is very different job than do custom milling cutter in a sprocket. Even if they are technical capable to do that, the focus of a Engine Machine Shop is not that.
When Passos said about reliability, he refer about the precision of machining. Anybody can machine anything, the precision of the job is the difference. So, to stop a big Machine shop (that have production line and need to stop everything to machine two sprockets) that can have the precision that we look at, will cost about the same to buy new sprockets.
MatheusS50 is offline   Reply With Quote
Old 20th June 2012, 06:39   #10
First e28 M5
Garage: E24 M6's
Hello Mr. Engine Builder...
Originally Posted by MatheusS50 View Post
Hi..
This comment definitely put a smile on my face...
Our doubtīs is not due timming, but fitment (example: pick up rotor for cam sensor that is used in B38, but in B36 and S14 is distributor rotor).
I think the way you are trying to find your need is very poorly wrote/asked without technical details etc....What you are saying above the words you have used does not make any sense
Indeed 'Pspassos' does not make his hands dirty as for example I, Raymond, Tomba, Wout, David, Darren and other board member..He, pspassos is using you Mr. Engine Builder in one word pspassos does not have the ability to build the engine.
I tried to give some general input to "Pspassos" about factory cam gears to 'Hop Up' and do mild upgrade. It has nothing to do with your particular engine build etc
No i never used one before...
Another very naive comment...In this country were the automotive industry, engine building is very advanced and people who own very big shops with very advanced machinery can do it. I am speaking from experience. Because I have done it many times. And if you having trouble to do so its all your problem.
As I always like to say "Quality Has its price" choice is yours. If something does not make sense for your $ do not buy it. No one is pushing you to do so.
Mr. Engine Builder. with your very poor technical description/question it made barely sense in my opinion...
I am willing to give my opinion wether its valuable to you or not. You should appreciate our board members the effort to help because you are the one who needs help not me/us the members, indeed you don't.
Today I made the effort to take some pics in order to help you Mr Engine Builder and Pspassos some one who is telling me that I have never seen a100 cam gear in my life, i like that..
Hear is S14 engine that I have completed not long ago I wont go in details and specification etc...
As you can see its has Individual coils for each cyl as S38-B38
Do you see some were the camshaft position sensor ?
Yes I will install adjustable cam gears very soon.
I have done this route you are trying to do..
A Homework is given to you Mr Engine Builder....
With best regards from worm California
Anri
Ferrari-Bmw (20th June 2012)
3.8 cam sprocket on 3.6 Gerg E34 M5 Discussion 11 4th September 2005 05:17
cam sprocket for 3.6 JamesD E34 M5 Discussion 1 8th August 2005 08:06
Appeal of an Exhaust Cam Sprocket samson E34 M5 Discussion 8 11th September 2002 15:00
Dinan Chip and Cam Sprocket? JPK//E28M5 E28 M5 Discussion 2 1st May 2001 15:20
Dinan Chip and Cam Sprocket? JPK//E28M5 E34 M5 Discussion 0 6th May 2000 16:37
