Head torque question S38B36 - BMW M5 Forum and M6 Forums
Like Tree3Likes
  • 1 Post By Tomba
  • 1 Post By uk_bm
  • 1 Post By davidoli
Old 3rd June 2012, 18:22   #1
pugnut87
Garage: 1991 BMW M5 Apline White
I have done hours and hours worth of reading trying to find information on this motor. And I had a friend at a dealer print out some information. I keep getting two different specs for head torque, I get the Head torque angles, and just a set 3 set torque value. When people have installed heads what does everybody else do?
Cheers
pugnut87 is offline   Reply With Quote
Old 3rd June 2012, 21:08   #2
davidoli
Phase :
1 = 15lbft
2 = 36lbft
3 = 58lbft
4 = 72lbft
5 = -90 * + 72lbft
TURN THE ENGINE UNTIL THERMOSTAT IS COMPLETELY OPEN
LET ENGINE COOL DOWN FOR 4 HOURS (WITH OPEN BONNET)
OPEN THE FILLER CAP OF THE COOLING WATER CIRCUIT EXPANSION TANK
Then repeat phase 5 .
91 Sebring 3.6 | E28 UK RHD M5 | E34 UK RHD 3.8 | E34 M5 Touring | E24 M635CSi UK RHD
www.classicmdautos.co.uk
davidoli is offline   Reply With Quote
Old 3rd June 2012, 22:44   #3
pugnut87
Ok so on Phase 5 you turn the bolts loose 90* then retorque to 72 ftlbs. ok
And after warm up when you have to repeat phase 5, can you get to the head bolts with the upper timing cover, the "upper head" portion in place, or do you have to remove that to get to them?
Thanks for the information.
Cheers
Old 5th June 2012, 12:33   #4
Tomba
Garage: BMW E34 M5 3.6 macaoblau
David, your torque sequence seems more relevant to M30 engine than S38... where did you get that sequence from?
E34 M5 3.6 Cylinder Head Tightening Torques
BMW TIS Documentation set the B36
1. 20Nm
2. 60 degrees
3. 70 degrees
No re-torque after heat up. IT would mean to disassemble the top of the head to re-torque it which is doubtfull in my opinion.
To///Mba
Tomba is offline   Reply With Quote
Old 5th June 2012, 16:07   #5
uk_bm
Garage: Avus blue E34 M5 3.8
I've been using this for torque settings. Aligns with Tomba's comments.
vehicle s38b38 bosch
uk_bm is online now   Reply With Quote
Old 5th June 2012, 20:36   #6
davidoli
1. 20Nm
2. 60 degrees
3. 70 degrees
My mistake .
Typed this from my home laptop which doesn't have my TIS on it , so took the info from one of my gasket suppliers websites as I happened to be on there at the time .
Been a while since we've had to do a head gasket , thankfully !
Thanks for correcting my mistake boys and apologies to OP for any confusion caused !
D
The Following User Says Thank You to davidoli For This Useful Post:
Tomba (5th June 2012)
E34 Want to buy: WTB: S38B36 Head + Cams Nicke28 Parts / Other For Sale or Wanted 0 10th February 2012 17:14
Spark plug torque setting S38B36 Bayerische E34 M5 Discussion 4 9th December 2011 19:51
S38B36 cylinder head repair Bajzath E34 M5 Discussion 32 28th August 2010 14:50
WTB s38b36 head for rebuild. adriver E34 M5 Discussion 3 31st July 2007 06:20
Need a S38B36 engine or head with valves Eryk_PL Parts / Other For Sale or Wanted 1 3rd September 2005 14:18
