AC Part Needed - BMW M5 Forum and M6 Forums
Old 28th May 2012, 19:07   #1
dputnam36
Garage: 1991 M5
AC Part Needed
After nearly 3 years of ownership I've finally worked my way far enough through the car to start focusing my maint budget on luxury items. I bit the bullet this spring and decided to have the AC fixed. Compressor works just fine, holds a charge, but after a full day of going through the system (and pulling the dash apart) my mechanic found the problem: the plastic box that holds the flaps/etc is cracked and doesn't function properly and results in one side of the car to receive cold air while the other gets heat. We've been unable to source one of these boxes. Anyone know where I can find one?
dputnam36 is offline   Reply With Quote
Old 28th May 2012, 19:42   #2
uk_bm
Garage: Avus blue E34 M5 3.8
Intersting problem, good luck with the sourcing.
I would be tempted to fix the housing if just cracked. Not an option?
uk_bm is offline   Reply With Quote
Old 28th May 2012, 19:52   #3
dputnam36
Garage: 1991 M5
We may be able to re-glue it, may not.
My biggest concern is causing even more damage removing it. I'd like to have a spare one before attempting to pull it.
Old 28th May 2012, 22:11   #4
davidoli
Where , exactly is the box that holds the flaps ?
Behind the centre console , below the stereo ?
D
91 Sebring 3.6 | E28 UK RHD M5 | E34 UK RHD 3.8 | E34 M5 Touring | E24 M635CSi UK RHD
www.classicmdautos.co.uk
davidoli is offline   Reply With Quote
Old 12th June 2012, 18:23   #5
theodoordegrote
theodoordegrote's Avatar
Garage: E34 M5 Touring, Mauritius Blue
Have a look on www.ebay.de and search for "e34 heizung", "e34 klimakasten", "e34 IHKA" or "e34 IHKR". Make sure to ask whether the seller is prepared to ship worldwide. I beleive Behr produced the IHKA (automatic) heaterboxes and Siemens produced the IHKR heaterboxes (manual).
If you have the automatic climate control, these sites might be helpful to you: BMW E32/E34 IHKA System, http://www.e38.org/e32/klimaautomatik.pdf, *DIY E34 heater core R&R (IHKA content) - Bimmerforums - The Ultimate BMW Forum.
theodoordegrote is offline   Reply With Quote
Old 12th June 2012, 18:23   #6
theodoordegrote
Part # Needed OptimusPrimeM5 E39 M5 and E52 Z8 Discussion 7 17th October 2011 21:49
Help needed - B7 turbo part Sherlock ALPINABoard.com | BMW Alpina Discussion 14 23rd August 2010 21:27
part number needed BMW x 2 E39 M5 and E52 Z8 Discussion 1 3rd November 2008 23:57
Part Number Needed hertfordshire1 E34 M5 Discussion 3 8th February 2005 23:38
Homelink part no. needed Serge E39 M5 and E52 Z8 Discussion 1 17th July 2001 22:14
