No power to fuel pump - BMW M5 Forum and M6 Forums
Old 15th May 2012, 18:22   #1
e34west
Garage: Diamantschwarz 91 Euro M5
Hi guys,
I have a 1991 Euro M5 that is giving me some fuel pump issues. The car is new to me and over the winter I had done some freshening up... vacuum lines, coil, cap, rotor, plugs, new battery and so on. Car ran fine when I parked it in the fall, but now when I go to crank it, the pump is not pumping any fuel. I jumped the relay and tested the plug that goes to the FP, and there's no power. I tried doing the same thing on my 525i, and it works fine.
One concern I have is that the car has an aftermarket alarm. I'm wondering that when I changed the battery, it may have affected the alarm's functions. Is it possible that even when jumping the relay, the alarm could be affecting the fuel pump?
Additional info... I have the 5 prong fuel pump relay. Swapped in the orange 4 prong from my 525i and no difference. Fuel pump is new. Fuse is good.
Thanks in advance...
e34west is offline   Reply With Quote
Old 16th May 2012, 16:52   #2
e34west
Any thoughts guys? How could the fuel pump not be getting any power when jumped? Is the fuel pump relay in the same location as a non-M5 e34? I'm looking at the middle of three relays in the E-box.
Old 16th May 2012, 17:26   #3
MattH
Garage: E30 M3 Misano Red
This is a long shot, but do a search for the Alan Archer posts on rear wiring harness issues. On his 3.8 (I note yours is a 3.6 so this harness is probably different) he had an issue where shorts in a worn part of the harness where stretched over the rear subframe caused issues with his EDC. I know because I have the same issue (my speedo is out and I'm pretty sure this is related).
So as I say, a long shot, because I dont know if the harness in 3.6's is prone to a similar failing - but worth searching to see if others have had the issue.
MattH is offline   Reply With Quote
Old 16th May 2012, 19:55   #4
uk_bm
Garage: Avus blue E34 M5 3.8
So far as I can see if the fuse F23 is 12v then the pump should be running.
It it is live then it's just wiring (feed or earth), or the pump.
uk_bm is offline   Reply With Quote
Old 16th May 2012, 21:01   #5
MY BUD
Garage: e34 3.8 M5, e34 B10 Biturbo, e39 530i.
Have you tried checking for spark as well as fuel? If you have neither then the crank position sensor could be at fault.
MY BUD is offline   Reply With Quote
Old 16th May 2012, 22:26   #6
e34west
Well when I jump the FP relay, there is no power to the fuse. I think I'll have a look around the wiring by the FP. If there is a bad ground back there, then there would be no complete circuit, and no power at the fuse, right?
Old 17th May 2012, 00:41   #7
uk_bm
You're bridging the relay socket with wire, or something?
Have you checked 12v at the socket? Another thought is that O2 sensor element is playing up and pulling down the voltage. Or no power into the socket etc etc.
Old 17th May 2012, 01:14   #8
e34west
Yes, bridging with wire. Power at all three sockets. 12 plus volts on each.
Old 17th May 2012, 15:26   #9
uk_bm
So we seem to be saying there is a break between the socket and fuse.
Old 17th May 2012, 17:21   #10
e34west
That what it sounds like. What about a bad ground? Could a bad ground in the engine bay affect the FP? I had a lot of stuff apart in there, and maybe something didn't go back together exactly right.
Fuel sender/fuel filter/fuel pump/ temperature gauge jack eiler E39 M5 and E52 Z8 Discussion 6 2nd May 2012 17:08
New pre cat 02 sensors, secondary air pump, mafs, fuel pump and filter = 1 happy S2!! madyspop E39 M5 and E52 Z8 Discussion 0 12th February 2011 04:37
Kenne-Bell Boost-A-Pump Install (AKA Dinan Fuel Pump Booster #D862-7320 havasusteve03Beast E39 M5 and E52 Z8 Discussion 2 11th November 2010 05:56
Loss of power mid-range on full throttle...Fuel pump??? Dave321 E60 M5 and E61 M5 Touring Discussion 7 13th May 2010 02:54
urgent help needed! fuel pump relay or pump itself?? jonnycowboy E39 M5 and E52 Z8 Discussion 14 1st October 2009 15:58
