Brazilian M5 on the track! - Page 4 - BMW M5 Forum and M6 Forums
Like Tree21Likes
Old 1st July 2012, 22:42   #31
First e28 M5
First e28 M5's Avatar
Garage: E24 M6's
Originally Posted by MatheusS50 View Post
did you fit this M88 header in your S38? Did you have problem with clearance? Is this M88 header 50mm primary pipes ending in both 58mm collectors? could you take more pictures of flange side?
Thank you to share with us this nice picture.
Matheus,
Took some pics for all of us S38 board members hear: M88/3, S38-B36-B38, S54-B32 Headers comparison.
Hope this will help little bit and give you an idea to improve passos headers decision/choice.
Regards
Anri
__________________________________________________ _________________________
- It is super fun to build your own custom car the way you want it and like it.
- E24 M6 1988. Shwartz/Tan Original condition. Daily driver, keeper, Dinan suspension, Dinan adjustable sway bars, Evo S14 A100 cam gear, TMS chip, 360mm 6pot front, BBS 17x9,5 BBS E26 Magnesium Race wheels wrapped 255's.
- E24 M6 1988 Shwartz/Grey Collectible for shows 100% all original unrestored, keeper..
- E24 M6 1988 Shwarts/Lotus For Sale E24 M6 http://euroclassicmotors.com/galleries/bmwm6e24.html.
- E24 M6 1988 Royal Blue/Lotus white S85-B50 Restoration in proses.
- E24 M6 1988 Shwartz/Recaro S38-B36 3.6 goal is ~52/48 weight distribution at around 2800 pounds. My Track car for Vintage Racing !
- E30 M3 1990 Euro B38 3.8 goal is ~52/48 at ~2800 pounds.
- E53 X5 3.0 2003 Wife's car.
- E31 840Ci 1997 Black/Black, CSI exterior.
First e28 M5 is offline   Reply With Quote
Old 4th July 2012, 03:43   #32
MatheusS50
Garage: E36 black
Originally Posted by DiegoR View Post
Hope not go O but there is any thread about the build or the specs? Sounds like a blast to rev!
Itīs GrandRoyal M3 E30!
I will convince he to open a thread here with his car and with some vids.
The basic spec is S14 converted to EVO 2.5 liters using special forging lightweight and balanced (within 0,5g in the set) pistons, OEM BMW Motorsport 87mm stroke crankshaft, i made special stage 3 headwork (changed valves, seat troat flow keeping port speed..decreased valvetrain mass and spring pressure corrected to work up to 9.000rpm without floating..), with inlet ports matching the Sport EVO 48mm Throttle bodies that he is also using.
The injectors are also replaced for higher flow (also to renew the old parts that with time loose tightness sealing between dwell time), but keeping spray angle and efficiency.
The engine is just in the initial step of mods. Itīs running in OEM Motronic keeping the AFM load setup. I did the engine calibration in the OEM Motronic, correcting the air/fuel ratio for new VE and also ignition timming. But is a very old and limited ECU (that even if we convert the AFM load type to new MAF type, will be limited in other areas... even if convert to Alpha-N in OEM Motronic that i also possible), so, i requested to GrandRoyal change to MoTec, then, i will can do a perfect engine calibration that this engine deserves.
MatheusS50 is offline   Reply With Quote
The Following User Says Thank You to MatheusS50 For This Useful Post:
DiegoR (4th July 2012)
Old 4th July 2012, 03:44   #33
MatheusS50
Garage: E36 black
Originally Posted by First e28 M5 View Post
Matheus,
Regards
Anri
Thank you!
Old 23rd December 2012, 17:29   #34
pspassos
pspassos's Avatar
Garage: 95 M5 3.8
bringing this topic back to life with some more videos...
two different days, two different weather conditions....
in the rain, I run like a pussy, I know it, hahaha
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
but in the dry I was a little bit better
+ YouTube Video
Nothing changed on the mechanics yet, unless the slick tyres (235x18 and 265x18)....
I have already got a pair of M88 headers to me slightly modified for my use, and some other stuf that I had mentioned before in this same thread....
'95 3.8 6speed ///M5
You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you rotect it like it's your family, then you drive it like you stole it.
pspassos is offline   Reply With Quote
The Following User Says Thank You to pspassos For This Useful Post:
kiudog (1st March 2013)
Old 1st March 2013, 20:32   #35
Mr Z
Garage: 1993 M5 canadian
What sort of modifications did you have to make to get the M88 headers to fit?
Mr Z is offline   Reply With Quote
Old 1st March 2013, 20:44   #36
pspassos
pspassos's Avatar
Garage: 95 M5 3.8
they will be installed by the end of this year only my friend
Old 2nd March 2013, 10:08   #37
Ferrari-Bmw
Garage: Alpina B10 Biturbo Ferrari Yellow
Is there for SURE ... improvement on using M88/3 vs S38B38 on b38 engine ??
Sveinbjörn Hrafnsson
E30 CABRIO S3 8B38
ALPINA B10 BITURBO 346 @ 507
http://alpina.123.is/pictures/
Ferrari-Bmw is offline   Reply With Quote
Old 2nd March 2013, 13:41   #38
MatheusS50
Garage: E36 black
What you mean by "improving"?
Itīs depends of your target.
Itīs the common error of exhaust manifold and exhaust downpipes setup decision. "Default" manifolds, downpipes and mufflers, usually, are made for average owners, that have standard engines and are looking for some additional power in top end, but never loose low and mid-range. So, itīs very hard to happen. Usually, these default manifolds with low diameter in primary pipes, just increase power in mid-range and some cases decrease power in top end. But, common customers will think that now have more power (the feeling of strong mid-range can mess the final power gain and the average power gain). Depending on the target, is not wrong. If you use your car more in mid-rage rpm, is better a exhaust manifold that delivery to you power in this range.
So, if i sell to you a Race exhaust manifold with big diameter primary pipes and you have a standard S38, you donīt will like the result. Will say that manifold decreased your power than increase.
But, for Passos engine, we will use a exhaust manifold that decrease exhaust port restriction in higher rev, to combine with special engine head that i made and the special high duration/lift/overlap camshafts.
We donīt will use M88/3 by factory, itīs will be modified, and for our application, yes, itīs a improvement.
There is no global answer for this question, itīs depends of your project and target. In high specific power output engines, everything is a trade-off. Is very difficult to have a "gain-gain" mod.
Another Brazilian M5 Fails GrandRoyaL E34 M5 Discussion 45 23rd June 2012 03:34
Brazilian Music... Kevin L. Johnson Off Topic Forum 2 22nd November 2006 16:33
Dear brazilian friends racer_xbr Regional Forums and Events and group meetings for M5, M6 and Alpina owners 0 2nd June 2006 03:55
Dear brazilian friends racer_xbr E60 M5 and E61 M5 Touring Discussion 0 2nd June 2006 03:52
OT: Brazilian G.P. > what'll happen??? Millie Miglia E39 M5 and E52 Z8 Discussion 16 5th April 2001 23:41
