Wheel paint code - BMW M5 Forum and M6 Forums
Old 28th July 2002, 17:13   #1
M5 powered
Garage: E46 CSL, 2004, Silver Grey- Factory De-limit / Alcon Front & Rear BBK, Pagid RS29's, CF 9kg Braille
Wheel paint code
Hi anyone have the paint code for the 18inch M-Parallel wheels handy. Just managed to kerb one avoiding some S**t head most probably in a stolen car. I'd leave it but it's quite bad and will involve the wheel being heated up and new alloy applied
Also does anyone know if the silver paint code on the BMW M5 is generic for all BMW rims?
regards
M5 powered
2004 M3 CSL, Silver Grey with Factory De-limit & Alcon 6 Pot BBK
1995 M5 Limited Edition (02/50)Rosso Red SOLD
M5 powered is offline   Reply With Quote
Old 30th July 2002, 21:50   #2
bibbya
Garage: E60 M5 Sapphire Black
Hi
I bought some a few months ago so I'll check for the code although it does seem too dark. I only needed a touch up brush but I was told they aren't available so I had to buy a tin.
If its all the same then you can have mine as I've found a Vauxhall brush which is a better colour match for the chips on my 94 throwing stars.
Andy
94 3.8
bibbya is offline   Reply With Quote
Old 30th July 2002, 22:28   #3
mywong23
mywong23's Avatar
Garage: e34 M5 black
heard that a place called Wurth stocks various wheel paints, as well as other accessories.
mywong23 is offline   Reply With Quote
Old 31st July 2002, 18:27   #4
M5 powered
Thanks for the replies,
I've now had the wheels all done including the kerbed one and the job is incredible. Can't even tell where it was welded and machined back!!
As for the colour, the very light silver used on the M parallels was just too difficult to get an exact colour match although it was close. The difficulty was in the metallic partical size so I've had all 4 done and painted with a very close match and they look pristine. If anyone is in the same position it's classed as 'orange peel'
Now to go and christen them on the nearest kerb LOL.
regards
M5 powered
Old 31st July 2002, 18:57   #5
mywong23
mywong23's Avatar
http://www.carcareonline.com
sells the Wurth paint for wheels.
Old 1st August 2002, 11:59   #6
bandit
Garage: BMW M5 E34 BLACK
How much?
Hi there.
How much did it cost to refurbish the wheels. I need to fix a curbed one as well (my mistake, slight wheelspin in the snow last winter and I rubbed it).
Thanks.
Bandit
bandit is offline   Reply With Quote
Old 1st August 2002, 18:36   #7
M5 powered
Hi Bandit
It cost around £90 per wheel which included them all being taken down to raw alloy again and being checked for any cracks + the welding and machining of the kerbed wheel. They were then all re-sprayed, sealed, new valves and balanced again.
for the UK this is quite expensive but having seen so many botched jobs at £50 per wheel where they have been over painted or filler used I just didn't trust anyone else.
the only thing I will say is that you really need to get all 4 done at the same time to get a colour match as like car bodies, it's near impossible and will be even more obvious on your design of alloys.
regards
M5 powered
P.S. I almost got them painted metallic black which would have looked quite good against the red of the car. But then I thought better of it. Don't think a buyer would be too impressed if I needed to sell it.
wheel code? jimmy01 E34 M5 Discussion 4 1st September 2002 01:39
2002 M3 paint issue Mr. Grinch E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 1 16th April 2002 05:03
Titanium Silver Paint Code? MWM E39 M5 and E52 Z8 Discussion 2 6th February 2002 06:02
Where is the paint code for my car stamped on the chassis? MWM E39 M5 and E52 Z8 Discussion 8 16th January 2002 07:33
Paint Code for Lemans Blue? nvmymr2 E39 M5 and E52 Z8 Discussion 1 25th April 2001 02:52
