10th February 2012, 14:11
#1
Hot start issue
Hello all,
I've just returned from the MOT tester with a successful result but I still have an underlying issue that is becoming very annoying.
The car struggles to maintain idle for 30-60seconds when restarted from warm. If the car is left to go completely cold, it will start without issue (apart from the obligatory noisey aux pump), but once this cycle is over and I try to start it again (without the pump having to engage) the revs hunt around and shudder the whole car as if the engine is on the brink of cutting out. If a little throttle is applied to increase revs, it makes the hunting worse and virtually cuts out.
Could anyone suggest where I may need to look first, then second, third fourth and so on until I find the culprit to get this resolved?
If it makes any difference, I have just replaced the voltage regulator in the alternator but I doubt the two are linked as the problem remains.
Many thanks
