volvo 33mm valve shims - BMW M5 Forum and M6 Forums
post #1 of 32 Old 10th December 2011, 03:23 AM Thread Starter
stija
What is the best and cheapest place to order the volvo shims or any other shims that will fit. My local BMW dealership wants 24$/shim.
Can anyone help. I can afford to have the car in the garage for a week so that is the timeframe id need them in as i plan to order the ones i need only. Thanks.
stija is offline
post #2 of 32 Old 10th December 2011, 06:55 AM
kupkake
I recently purchased various shims from thebmwpartstore.com.The prices varied from under 9.to $13. and change.Shipping charges very reasonable;prompt delivery.My 3.8 was professionally rebuilt.Figured I'd treat it to BMW shims rather than Volvo to start it's new life.
kupkake is offline
post #3 of 32 Old 10th December 2011, 08:39 AM
Stuttgarter///M5
Stuttgarter///M5's Avatar
Check out this place:
www.partsgeek.com
Now, I've never used them, but the prices look right and everything is in stock.
Or if you wanted something more affiliated with BMW you could check out this place:
www.bmpdesign.com
I've never used them either. But even at 6 bucks you're better off than throwing your money away at the dealership.
Good luck,
Dave
Stuttgarter///M5 is offline
post #4 of 32 Old 10th December 2011, 05:33 PM
jsh
jsh is offline
post #5 of 32 Old 10th December 2011, 07:05 PM
bubba966
bubba966's Avatar
Originally Posted by jsh View Post
Stija:
I used this:
Valve Shim Kit
it worked out well they are a good outfit.
john
$250 isn't bad, but $199 is a bit better.
CRP W0133-1604802 Valve Spring Shim | Auto Parts Warehouse
bubba966 is offline
post #6 of 32 Old 10th December 2011, 07:17 PM
Blitzkrieg Bob
Blitzkrieg Bob's Avatar
Parts Geek has the best deal on the kit at $167.35
1990-1993 Volvo 240 Valve Adjust Shim Kit - Engine Mechanical - CRP 90-93 240 Valve Adjust Shim Kit - 768-01021929 - PartsGeek
1990 525 Alpine Weiss, Miller MAF conversion, Eibach springs, and Dinan cigarette lighter.
1991 M5 Sterling Silber with TMS chip, SLS delete, UUC SSK & DSSR, M Tech EVO II Wheel, Eibach springs, RD Bilstein struts and Stebro exhaust.
1991 M5 Alpine Wiess slowly coming together with a rebuilt MAF, M pars and a B&B exhaust
Blitzkrieg Bob is offline
The Following User Says Thank You to Blitzkrieg Bob For This Useful Post:
vitomir (29th November 2013)
post #7 of 32 Old 10th December 2011, 08:01 PM
215m3
215m3 is offline
post #8 of 32 Old 10th December 2011, 10:16 PM
bubba966
bubba966's Avatar
Originally Posted by Blitzkrieg Bob View Post
Nice, even better.
Luckily my M60 & M50 don't need those. Will have to remember that if I or anyone else I know ever needs a kit...
bubba966 is offline
post #9 of 32 Old 12th December 2011, 04:41 PM Thread Starter
stija
Thanks for your help. I myself too found a website (i saved in favorites on my desktop) that sold shims for like $2+ so that shouldn't be a problem. I'll just need to verify that they do have them in stock for sure.
I am going to attempt this today. Or start i should say. At the same time i will be changing all the vacuum hoses with the vacuum hose kit purchased from ebay as in nikosx thread. I also purchased the carbtune tool to adjust the itbs.
If anyone has any input or hints or tricks on how to do some things easier, please do chime in. I'd rather learn on someone else's mistakes than by braking or struggling with something on my car
stija is offline
post #10 of 32 Old 12th December 2011, 07:05 PM Thread Starter
stija
My car is stock except for the jim conforti tms chip. It runs on 91 octange gas and i live in arizona USA. What should i be aiming for as far as clearances go for exhaust vs intake valves. It seems that the recommended is .28mm intake and .33mm exhaust. I will be using the table that bondy created in one of the threads here and modify it as need be.
Can I reuse my old shims if after measuring with a digital caliper they measure a size that i need?? And what size is the crank bolt?? I've seen anything from 27mm 32mm or 36mm. Realoem.com doesnt specifiy the bolt size
stija is offline
S38 valve shims connorb850 E34 M5 Discussion 16 11th May 2010 11:45 PM
E34 M5 valve shims marekd174 E34 M5 Discussion 8 2nd July 2009 04:05 AM
Trying to remove valve shims from tappets Robinson E34 M5 Discussion 2 24th July 2008 09:05 PM
Help me- M88 valve clearances....15 shims reqd farrell E28 M5 Discussion 16 2nd March 2008 12:19 PM
Need Education: Teflon Shims chunpng E39 M5 and E52 Z8 Discussion 11 3rd July 2002 06:12 PM
