Adjustable Front Top Mounts - BMW M5 Forum and M6 Forums
Old 9th November 2011, 17:39   #1
215m3
Garage: M3 Turbo & E34 M5
My M5 has failed it's MOT on a rear strut badly leaking and a cracked coil. I am going to replace the whole lot with some coilovers. The ones i am looking at don't come with top mounts.
Is anyone currently rnning adjustable top mounts?
I have a set on my M3 and if the PCD of the mountng nuts are the same i will use these as the M3 is not running at the moment.
Need to get these ordered by tomorrow at the latest so i can fit the suspension at the weekend.
I will need to temporarily block off the SLS until i can remove all the pipe work.
Toby
1987 E30 M3 Turbo
1990 E34 M5
215m3 is offline   Reply With Quote
Old 9th November 2011, 18:18   #2
davidoli
I'm sure that I'd have a rear sls shock with spring for you Toby , as it seems a shame to ditch the whole set up .
D
91 Sebring 3.6 | E28 UK RHD M5 | E34 UK RHD 3.8 | E34 M5 Touring | E24 M635CSi UK RHD
www.classicmdautos.co.uk
davidoli is offline   Reply With Quote
Old 9th November 2011, 18:26   #3
215m3
D
I know, but i want to lower the front end. Also the front and other shock may need doing too, so if i replace all for with new shocks and springs then it will be a fresh setup.
What price for the shock?
Old 9th November 2011, 18:45   #4
davidoli
I'll check what I've got tomorrow and call you Toby .
Sounds like that track day may have mullered your suspension ?!
D
Old 9th November 2011, 19:50   #5
215m3
the strut was leaking before then. let me know a price if you could driver side. my luck i replace the one strut and the other side goes. just thinking replacing all will freshen the whole set up.
Old 10th November 2011, 15:50   #6
215m3
Orderd BC Race coilovers and got them at trade price, the same price as one strut. Will see if my ground control top mounts will fit from my M3.
they come with a spacer to allowm more neg cambrer and castor as seen in the picture below
Old 10th November 2011, 15:59   #7
215m3
Ordered BC Race stree/circuit coilovers and got them at trade price, the same price as one strut. Will see if my ground control top mounts will fit from my M3.
[/quote]
HD Rear Top Mounts? Bayeriche M E34 M5 Discussion 4 31st July 2011 05:16
E34 For Sale: Rear top HD mounts Meyle (M5) pair Bayeriche M Parts / Other For Sale or Wanted 0 31st July 2011 05:12
camber plates / adjustable top mounts hugo E34 M5 Discussion 2 15th October 2009 07:42
E34 shocks and top mounts nulkki E34 M5 Discussion 9 28th July 2008 09:29
advice on top mounts gavinp E34 M5 Discussion 4 23rd May 2007 03:22
