Balancing the throttle bodies with the Carbtune tool - BMW M5 Forum and M6 Forums
 13Likes
post #1 of 131 Old 20th September 2011, 03:23 AM Thread Starter
mc hammered
The previous owner told me he balanced the throttle bodies, however, in the interest of learning ow to do this myself I purchased a Carbtune tool to help with this maintenance step.
The Carbtune allows you to view 4 of the TBs at the same time which I think is a big bonus in doing this maintenance vs. doing each TB individually.
They include some small orifice tubing to make restrictors otherwise the rods bounce up and down too much to get a reading. Since I already designed an inline restrictor for the gauges I sell I chose to use that instead
Plugs on the vacuum ports removed, lines plumbed in and connected to the Carbtune
This is how the first 4 throttle bodies are adjusted. From left to right it is cylinders 4,3,2,1
According to the BMW service manual the TB should be adjusted to 300mbar or 22.5cmHg so using a 7mm socket you tweak the adjusters to even out the readings. Turn left to reduce, turn right to increase.
Plugs on cylinders 5 & 6 removed and put onto 1 & 2, lines from the carbtune plumbed in
So using cylinders 3 & 4 for reference we adjust 5 & 6. From left to right 4,3,6,5
After adjustment. The car does idle better and when I checked the tach the needle used to sit at 1000rpm, now it sits a bit below it.
My 1991 M5... this is Veronica
My 1989 325i convertible (sold)... this is Nina
mc hammered is offline
The Following 12 Users Say Thank You to mc hammered For This Useful Post:
///Manuel (20th September 2011), corneredge (21st September 2011), Crash & Burn (23rd September 2011), Feld1128 (13th July 2014), Ficelle (8th August 2013), First e28 M5 (22nd September 2011), jorijori (22nd September 2011), Lantz (21st September 2011), NC BMW Driver (19th August 2012), pspassos (21st September 2011), raymondw (24th September 2011), SamB (20th September 2011)
post #2 of 131 Old 20th September 2011, 05:20 AM
blacktop540
blacktop540's Avatar
I always wondered why the M5s I've been in idle higher than usual and I've only been in and driven the 3.8 I myself own one and the idle seems to be fine not too high but still compared to my other BMWs. I guess they can all use some fine tuning? This is a good tool I should get one for myself. Great thread by the way! I don't understand where all the e34 guys are there's barely any threads.
blacktop540 is offline
post #3 of 131 Old 20th September 2011, 12:09 PM
SamB
SamB's Avatar
SamB is offline
post #4 of 131 Old 20th September 2011, 11:33 PM
davidoli
Marvellous thread , thanks for sharing .
D
91 Sebring 3.6 | E28 UK RHD M5 | E34 UK RHD 3.8 | E34 M5 Touring | E24 M635CSi UK RHD
www.classicmdautos.co.uk
davidoli is offline
post #5 of 131 Old 21st September 2011, 07:38 PM
pspassos
pspassos's Avatar
very good!
'95 3.8 6speed ///M5
You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you rotect it like it's your family, then you drive it like you stole it.
pspassos is offline
post #6 of 131 Old 22nd September 2011, 06:01 AM
First e28 M5
First e28 M5's Avatar
I am ordering the carbtune tool for the next few days...
Anri
__________________________________________________ _________________________
- It is super fun to build your own custom car the way you want it and like it.
- E24 M6 1988. Shwartz/Tan Original condition. Daily driver, keeper, adjustable coil overs , Adjustable Torsion bar, Evo S14 A100 cam gear, TMS chip, 360mm 6pot front, BBS 17x9,5 BBS E26 Magnesium Race wheels wrapped 255's.
- E24 M6 1988 Shwartz/Grey Collectible 100% all original unrestored, keeper..
- E24 M6 1988 Royal Blue/Lotus.
- E24 M6 1988 Shwartz/Sparco S38-B36 3.6. F49%-R51% weight distribution at around 2950 pounds. My Track car for Vintage Racing !
- E30 M3 1990 Euro B38 3.8 goal is ~52/48 at ~2800 pounds.
- E53 X5 3.0 2003 Wife's car.
- E31 840Ci 1997 Black/Black, all CSI futures daily driver.
First e28 M5 is offline
post #7 of 131 Old 22nd September 2011, 07:42 AM
2man
2man's Avatar
i wonder if theres a place that i can rent one from? mc hammered, im not too far away from you. can i rent it from you?
Current Stable:
-91 E34 M5 with Dinan Chip & Cam sprockets + more
-83 Jetta Coupe Project
2man is offline
post #8 of 131 Old 22nd September 2011, 06:34 PM
DiegoR
I purchased the SyncPro stuff (made for bikes and use glycol instead of mercury) and it works OK. I couldn't get consistent reading between some cylinder vs each other. Then I took the vac gauge that came in my craftman vacuum pistol and ran the vac line with the SyncPro super small restrictor and set the every cyl to 23inHg. I also synchronized the ITB's plates/arms and the whole idle of the car is more "solid" than before and it seat about 14.3 AFR according to my WB sensor.
You can see here the 1st cyl is not matching very well the rest, but with the vac guage I could set all the same, not sure why. I also checked my valve shims and were within specs.
Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
DiegoR is offline
post #9 of 131 Old 23rd September 2011, 04:16 AM
stija
I have a question about using this tool. Actually more than 1 question.
First off, how do you know that the tool is calibrated properly? Meaning, how do you know that when it reads 23 it actually is reading 23?? Have you tested it or calibrated it on something that you know the exact reading of??
Secondly, how do you know that all 4 bars are calibrated to each other?? Meaning, how do you know that if connected to the same ITB all 4 would read the exact same value?? Have you tried it?
I am just thinking aloud here.
stija is offline
post #10 of 131 Old 23rd September 2011, 04:26 AM Thread Starter
mc hammered
Your question is valid for any tool like this, even dial gauges, unless you happen to have a reference vacuum source to test it against.
So in this case I do have to trust the manufacturer that they are selling a calibrated product and I do know that screwing up the calibration of a dial gauge is a much easier than 4 steel rods.
From the www.carbtune.com FAQ
Q. Is it as accurate as dial or clock type gauges?
A. Yes. Infact it is more accurate than any dial or clock type gauges that we have tested. It has better resolution than typical dial gauges and is also much easier to read. The four columns are right beside each other for easy comparison unlike the pointers in dial type gauges.
Q. My dial gauge pointers flicker up and down. Is the Carbtune II better damped?
A. Yes. The moving part in the Carbtune II is a solid rod. This is too heavy to flicker wildly up and down. It does flicker a bit without any damping but with the damping supplied with the Carbtune II the fluctuations are very small. In fact the Carbtune II needs a little fluctuation to work properly. We can supply stronger dampers if necessary.
Q. My dial gauges always need recalibrating, is this necessary on the Carbtune II?
A. No. The components of the Carbtune II are matched during assembly at the factory and will not need any recalibrating. They work on a different principle to dial gauges.
Throttle Body Balancing 215m3 E34 M5 Discussion 21 14th May 2012 11:27 PM
Throttle Body Timing/Balancing - Dinan S3 x703jko E39 M5 and E52 Z8 Discussion 3 19th October 2010 05:45 PM
need help with throttle body balancing screws Konfused Pete E34 M5 Discussion 0 9th November 2009 02:09 PM
Balancing throttle bodies lagoonM5 E34 M5 Discussion 6 2nd November 2005 02:34 PM
8 Throttle bodies vs Dual Throttle bodies, Dinan Myth? MIB E39 M5 and E52 Z8 Discussion 6 26th December 2003 04:33 PM
