15th October 2010, 21:27
#1
1991 M5 Brilliant Red
Coolant level switch warning
Board, while disassembling my expansion tank for replacement I found a problem you all might want to be aware of.
The float in the radiator level switch (#3) was stuck in the up position due to crud between the float and the sensor.
This will prevent you from getting a coolant low warning.
A slow leak might go undetected up until the point you get a rise in water temp and overheat.
91 Brilliant Rot, Black Full Leather, SLS delete, Koni adjustables all corners with Eibach springs, UUC Short Shifter, Throwing Stars,
