Ignition Barrell Starting Problem - BMW M5 Forum and M6 Forums
Old 25th April 2010, 12:34   #1
215m3
Garage: M3 Turbo & E34 M5
Another problem, arose yesterday, but can't find anything on the search function.
After a 20 minute drive parked the car on the drive. I then needed to move her back to get the trickle charge on and the key would not turn in the ignition. I unlocks the steering lock, but then only turns about 5mm more. I Have tried to stick a needle in the small hole to remove the barrell, but that does not work either.
Any help on this issue would be great as she is now stuck in the middle of my driveway.
Toby
1987 E30 M3 Turbo
1990 E34 M5
215m3 is offline   Reply With Quote
Old 25th April 2010, 16:26   #2
davidoli
Hi Toby , if you really want to get the car started without the use of the key , send me an email to david@classicmdautos.co.uk as I'd prefer not to mention the method on open forum .
D
91 Sebring 3.6 | E28 UK RHD M5 | E34 UK RHD 3.8 | E34 M5 Touring | E24 M635CSi UK RHD
www.classicmdautos.co.uk
davidoli is offline   Reply With Quote
Old 25th April 2010, 19:57   #3
215m3
Email sent cheers
Old 25th April 2010, 23:02   #4
davidoli
Replied Toby .
D
starting problem gtn301072 E39 M5 and E52 Z8 Discussion 13 21st August 2009 06:40
Starting problem ///M5 Touring E34 M5 Discussion 22 15th February 2009 23:38
Problem with M5 Ignition! Siraris E60 M5 and E61 M5 Touring Discussion 2 25th September 2008 04:24
Starting problem m5bmer E39 M5 and E52 Z8 Discussion 8 30th August 2005 18:21
starting problem amir E39 M5 and E52 Z8 Discussion 0 29th August 2000 20:09
