S38B36 & S38B38 differences... - BMW M5 Forum and M6 Forums
Old 13th April 2010, 20:15   #1
tomson
tomson's Avatar
Garage: 1990 Sterling Silver M5
Hi,
I have done some checking on realoem and can see the two engines have different cylinder heads from the part numbers but is there a visual check I can do ? The engine is built up so I cant measure the intake valves either!
Thanks !
Tom
E34 M5 3.6 Sterling Silver Individual
E34 M5 3.6 Schwarz II
E30 Touring S38B36 Powered
And a few others!
tomson is offline   Reply With Quote
Old 13th April 2010, 21:00   #2
tomson
tomson's Avatar
Another one then, will the B38 head work with the B36 bottom end?
Old 14th April 2010, 11:15   #3
tomson
tomson's Avatar
I'm starting to think this is what I've done, with a 3.6 head gasket.
Does anyone know if the combustion chambers are different sizes ?
Old 14th April 2010, 14:36   #4
Lantz
Lantz's Avatar
Garage: BMW M5 E34 Granitsilber Metallic 3.8
I am pretty sure that a 3.6 bottom end can work with a 3.8 head as this is often the setup used when the S38 is tuned. The 3.6 bottom end is regarded as more durable as it has less stroke than the 3.8, and therefore the bearings tend to last longer.
I am not an engineer and could very well be wrong though, so i'll let others chime in.
Lantz
3.8 E34 M5
18" BBS LM
76mm Eisenmann Race
Lantz is offline   Reply With Quote
Old 14th April 2010, 16:25   #5
tomson
tomson's Avatar
Thanks Lantz.
The engine has timed up fine and spins over without any interferance by hand ok.
What I'm worried about is if the compression ratio will be dropped by what I've done?
I dont even know this for sure but its looking like thats what has happened...
When I bought my M5 the engine was out and stripped and there was a spare engine with it which the previous owner told me he bought for the head and this head he fitted to the cars engine. I removed it to inspect everything and refitted the same head after cleaning everything up. I have looked at the leftover bottom end more closely yesterday to find the pistons are marked S38B38
The last of the parts I need to try and start her arrived from BMW yesterday so I'm hoping to get her running on Saturday, until this which is worrying me now ...
Old 14th April 2010, 16:28   #6
GoneAgain
GoneAgain's Avatar
Garage: 1988 Sebring Grey.....reborn
Aren't the blocks stamped with the displacement?
GoneAgain is offline   Reply With Quote
Old 14th April 2010, 22:37   #7
tomson
tomson's Avatar
Yes, I can see there are markings on the block, now, its the head I need to identify...
Old 15th April 2010, 13:49   #8
MM-5
MM-5's Avatar
Garage: BMW M5 3.8 1992 Daytona Violet
Hi
Check the intake port diameter, if throttle bodies are not mounted. S38B36 diameter is 28 mm and S38B38 has 29,2 mm diameter intake ports. You can also see the difference from the exhaust side front end covers (cam gear covers). In 3.6 there is cover for distributor and in 3.8 there is camshaft trigger cover/sensor.
I hope this helped You .
Best Regards, Janne.
MM-5 is offline   Reply With Quote
Old 18th April 2010, 22:51   #9
tomson
tomson's Avatar
Hi Janne, the intake post sizes is most helpful, i'll be measuring them this week, thanks very much !
The cam trays are the same on 3.6 & 3.8 but as you say the 3.6 has a distributor and the 3.8 a sensor but these mount in the same way to the cam tray so it doesnt give me 100% confirmation, the intake port sizes do though . . . .
Thanks again
S50B32 chain tensioner upgrade for the S38B36 and S38B38 raymondw E34 M5 Discussion 67 9th September 2012 19:01
Cam Questions - Schrick, S38b36, & Installation ajw45 E28 M5 Discussion 7 15th July 2010 17:25
Differences between MY2007 & MY2008 M6? aeropa E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 8 24th September 2007 08:23
Differences between MY2007 & MY2008 M5? nyc123 E60 M5 and E61 M5 Touring Discussion 13 5th July 2007 22:57
S38B36 flywheel+clutch on s38b38 ? DrSakke E34 M5 Discussion 19 6th October 2003 20:23
