if it's cosmoline (probably is) you can also use solvent, and much labor (and maybe a pressure washer) to remove it. I worked at a bmw dealership's detail shop while i was in college (and these cars were new) and we usually removed most of it on the m cars and showroom bound cars.
If it's actually the paint (i.e. it feels smooth, not rough or sticky), i'd try a mild rubbing/polishing compound to see if it cleans up the paint.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
