Old 8th November 2009, 00:02   #1
richardbaxter
Lower section of Front Wings
With most well used cars (like mine) I thought it might be useful to highlight the rust issues at the lower section of the front wings.
The inner wing plastic shields do protect the vulnerable area behind them but only to a certain extent!
5 years ago I noticed some rust bubbles on the wings just above the plastic sill covers. After removing the sill covers and the wings the build up of fine silt was quite amazing and of course this material holds moisture allowing rust a feeding frenzy. The lower section of the wings had been eaten away leaving the lower section paper thin in metal content.
I decided to replace both front wings and in so doing prepared them for longer term protection by having the inside painted and then covered the new paint with waxoyl.
This weekend I removed the front spoiler (for repaint) as it is stone chipped to buggery, the inner wing plastic shield has to be removed (to remove the front spoiler) and it gave me the opportunity to check the lower front wing.
These were again filled with 'moist crud' and fortunately the earlier protectant has just about! done a good job in keeping the rust at bay.
So it seems to me this is a very vulnerable area and would strongly advise a 3 year check to remove the crud and check all is well!!! My concern is whether in the years to come the front wings will still be made available if not this will be a tricky repair to carry out.
Preventive maintenance is crucial here!
richardbaxter is offline
The Following User Says Thank You to richardbaxter For This Useful Post:
1day (8th November 2009)
Old 8th November 2009, 00:34   #2
1day
Garage: E34 M5 1991 white
thanks Richard,
I have been wondering just how long the rust repairs currently underway on my car will last, and root causes....
car currently looks like this...
it's strange when you see your car semi naked...
1day is offline
Old 8th November 2009, 00:37   #3
Ratty
Ratty's Avatar
Garage: 1991 E34 M5 Jet Black
I've just cleaned all the silt from my front sills too... exactly the same as described.
I dried it all out with a hair drier and it's still solid. Someone had painted it a few years ago, so I used a rust killing primer and topcoat.
Should keep the worms at bay for a while longer
Ratty is offline
Old 8th November 2009, 02:49   #4
Josco010
Garage: e30 m3 evo1 Lach silver
Thanks for the tip Mr Baxter, one thing bothers me though how come this is the case with this cars, i know that is a silly question to ask but i read somewhere the regular e34's don't seem to have this issue although i don't know this to be fact. I (I'm 2nd owner)have an e30 //m3 from '87' it's got 102k's on it and recently someone went over the car inside out and it is bone dry(No rust) so although i was told this was unusual in my case but i suspect there are others in good condition aswell, so for a later car i am amazed moreso because it seems to be common with this cars. Thanks once again.
Josco010 is offline
E39 Want to buy: Lower front bumper mesh grill and... right hand side (USA drivers) Lower wheel well Hdhntr23 For Sale or Wanted 5 2nd November 2009 03:19
Installing Lower Section Race Mesh Grill EMVY E60 M5 and E61 M5 Touring Discussion 2 7th December 2007 16:37
Economic section : will Greenspan lower FED's rate on Tuesday ? ydelta Off Topic Forum 5 10th August 2002 21:52
Pair of front wings needed. jimmy01 E28 M5 Discussion 0 1st March 2002 03:07
Page generated in 0.10580 seconds with 12 queries
