HI everyone,
My S38B36 engine is now finally run in after 1200km of not taking it over 4000rpm.
So yesterday i floored it and took it for the first time over 4k and then, DISAPPOINTMENT!!
It goes nice up to 5000rpm and then chokes(does not want to go any further) when 'Wide Open Throttle' is achieved.
What was strage to me is that if you floor it and lift your foot just 1 - 2 mm up, then it revs smooth all the way to 7000.
I then bought a set of new spark plugs and it was better but the point of trouble now doesnt start on 5000 anymore but the same problem now arises at 6000rpm. it still goes smooth when just OFF W.O.T.
To check, i drove it with a gas analyser and the a/f ratio stays on +- 14.7 the whole time, but as soon as it is on W.O.T it overfuels the engine completely starting at a/f 12.9 at 3000rpm and rising up to a a/f ratio of 10.5 at 6000rpm where it starts choking.
What went wong??
Could the software go corrupt while standing without a battery for 4 months?
Can the mixture be adjusted or reset at all, because it seems to me that the allen adjustment screw on the MAF only affects idle and very small throttle opening?
This is now after i tried new: plugs, ht leads, distributor cap, rotor, MAF with no effect exept the plugs that extends the problem a 1000rpm further down the rpm range.
Thanks in advance
Chee"
RS"
PS- the south african versions had no lambda sensors, nor cats, nor air pump, nor egr
