you guys have been a golden resource, cant thank you guys enough
Toronto's traffic is a mess - no matter what day or time - it's always a nightmare.
When my car sits in traffic for quite sometime - the oil will get to about 90 degree's Celsius [and the engine temp stays at center] and after driving it and bringing it back to idle it will rest at 1250 rpm - to about 1500 rpm.
If I give it a good rev - usually 3000+ it'll come back down to 1000 rpm or just slightly less.
does anyone know why this happens? I use sunoco 94 premium...
In Soviety Russia, car drives you!
Throttle bodies linkages might be sticking and could need a clean. or perhaps the same with your idle control valve. Have a friend with a E36 M3 and it used to idle at about 1500rpm also until we took out the ICV and gave it a clean.
Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 3_1_2 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7D11 Safari/528.16)
Does it matter if ac is on? I had a bad throttle switch (at the front of the engine/ throttle linkage) which kept the revs up near 2k when hot with ac on.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
I tend to agree with previously mentioned sticking throttle linkages. Check your cables that they are working freely and that your mechanical linkages are not binding.
+1 on this. I was having the same problem as Grannyshift, I just cleaned the linkages with WD-40 and its gone away. Revs up and down nicely now. Try cleaning first, before looking at the ICV. I just changed mine about 3k km's ago.
Adjusted the AFM against the CO2 readings, and its so much smoother now.
