Old 29th October 2009, 07:38   #1
///M5 Touring
Garage: bmw e34 m5 touring schwars II
shaking in the driveline
hi.
i have a sort of shaking in the driveline in 2nd and 3rd gear. in 2nd gear its from 1400rpm-2300rpm approx. in 3rd its from 1000rpm-1500rpm approx.
anyone have any tips of what it can be?
///M5 Touring is offline
Old 29th October 2009, 08:54   #2
vadas1
vadas1's Avatar
Garage: 1994 m5 / diamond black
Just a guess. Check your rear suspension bushes.
ralph (vadas1)
* If it ain't broke fix it till it is *
vadas1 is offline
Old 29th October 2009, 11:02   #3
farrell
farrell's Avatar
Sales Feedback: (4)
Sounds like its road wheel speed related.
Engine ok as an assumption.
Check the wheels are not loose or a wheel balance weight has not detached.
Also, check the wheels for dents or buckling that would drive an out of balance shake.
Check the driveline bolts & prop guibo coupling are tight & not breaking up.
The above could also make exhaust heat shields above rear & intermediate mufflers tizz.
Cheers
Farrell
www.darjac-racing.co.uk
farrell is offline
Old 30th October 2009, 03:07   #4
ilovemy_e34
Garage: 1991 M5 Brillant Red
Sounds to me like the carrier bearing is going out. Before the rubber bushing that holds the bearing completely disconnects it will shake/wobble in low rpm high torque conditions. This is my experience anyway. I would do a visual inspection of the carrier bearing along with guibo like farrell said.
-Cory
Even the wisest of doctors are relying on scientific truths, the errors of which will be recognized within a few years time. – Marcel Proust
ilovemy_e34 is offline
Driveline clunk Emmasis E39 M5 and E52 Z8 Discussion 20 14th March 2008 02:16
Driveline whine... bsbeals E39 M5 and E52 Z8 Discussion 4 6th September 2006 21:26
driveline losses not a fixed quantity? Pete E39 M5 and E52 Z8 Discussion 8 1st January 2005 21:58
Help - I just blew something in my driveline beanboy E39 M5 and E52 Z8 Discussion 6 7th December 2003 21:21
Driveline Shudder GK E39 M5 and E52 Z8 Discussion 4 8th October 2002 00:51
Page generated in 0.09486 seconds with 11 queries
