Old 28th October 2009, 23:24   #1
Montanvs
Montanvs's Avatar
Garage: 93 Avus Blue E34 M5
Peake Research Tool & new code table provided
I have recently been in touch with Peake Research regarding my scan tool. I had used it recently and was not able to find the code on the table that they stated it would be on in my manual. Through speaking with their department and providing them with my last 7 VIN they stated that a new code table that had not yet been published was coming out. As such they provided me with the new code table for our cars (at least for my car 3.8l).
The code that I had shows up on the table (1A Control unit supply). Seems the vehicle noticed that my battery had been unplugged and the DME was not getting power.
Here is the table for anyone else that uses the tool, or is thinking of getting one. This table (K8) seems to be accurate now.
Code System or Sensor
01 Electrical fuel pump relay
02 Idle speed actuator (close)
03 Fuel Injector, Cyl #1
04 Fuel Injector, Cyl #3
05 Fuel Injector, Cyl #2
06 Fuel Injector, Unknown
08 Check engine lamp
0C Oxygen sensor, #2
0D Oxygen sensor, #1
0F Ignition secondary monitor
10 Crankshaft sensor
11 Camshaft sensor
13 Secondary air pump relay
17 Ignition Coil, Cyl #2
18 Ignition Coil, Cyl #3
19 Ignition Coil, Cyl #1
1D Idle speed actuator (open)
1F Fuel Injector, Cyl #5
20 Fuel Injector, Cyl #6
21 Fuel Injector, Cyl #4
24 Evaporative purge control valve
25 Oxygen sensor heating relay
29 Air mass sensor
2A Vehicle speed signal not present
30 A/C Compressor control
32 Ignition Coil, Cyl #4
33 Ignition Coil, Cyl #6
34 Ignition Coil, Cyl #5
36 Battery voltage / DME main relay
41 A/C Compressor
42 DWA/EWS Input
44 Knock Sensor, Cyl 5-6
45 Knock Sensor, Cyl 3-4
46 Knock Sensor, Cyl 1-2
49 Throttle position sensor
4D Intake air temperature sensor
4E Coolant temperature sensor
64 Output Stage, Group #1
65 Output Stage, Group #2
C8 DME Control Unit
C9 Lambda Control #1
CA Fault code memory error
CB Lambda Control #2
CE Knock control test pulse
Montanvs is offline
The Following 3 Users Say Thank You to Montanvs For This Useful Post:
corneredge (7th November 2009), mottati (29th October 2009), pspassos (8th November 2009)
For Sale Peake Research Scan Tool Roundel For Sale or Wanted 1 7th July 2009 17:52
Peake R5 tool Table 40, Fault F0 SRS code josiahg52 E39 M5 and E52 Z8 Discussion 3 19th May 2009 21:48
Peake code table for x5 maxrpm E39 M5 and E52 Z8 Discussion 1 2nd December 2008 18:02
NEW PEAK RESEARCH R5 FCX3 CODE READER.......Indicates Incorrect Code Table for E39 M5 (Known Issue). Jim Green E39 M5 and E52 Z8 Discussion 12 10th May 2008 03:14
Peake Research R5/FCX tool... BlueBomber E39 M5 and E52 Z8 Discussion 4 29th February 2004 22:17
Page generated in 0.06772 seconds with 11 queries
