Old 24th October 2009, 09:43   #1
Frits
Frits's Avatar
Garage: E36 M3 alpine white E39 M5 avus blue E24 M635CSi royal blue
Help! Heavy vibrations
Guys, I need some help here. We have an E34 M5 Touring in the shop, which has an annoying issue with vibrations.
It starts at speeds usually higher than 80 km/h. Haven't tried anything faster than 130 km/h. When you slightly hit the brakes, or go through a pothole, it can start. Not always. It starts with just an annoying vibration, but it keeps getting worse and worse, and a few seconds later the whole car is shaking. Yesterday I was driving it in the evening, with the lights on, and I could see the beams go from left to right. Even with no pedals pressed, it keeps on going.
I once tried to press the accelerator while it was vibrating, and it seemed to get better then. Not sure if it was just luck this time, or if it really helps.
Now, customer allready changed plenty of parts, all the bushes/arms of the front suspension, front rotors. We changed the front shocks too. Doesn't help at all...
We checked everything at front, but can't find anything. It might be the steering box, but that would be an expensive guess... So I thought it would be a better idea to get some help from the board. So guys, please help. Someone must have had the same problem...
Frits is offline
Old 24th October 2009, 10:05   #2
Steve Mac
Steve Mac's Avatar
Garage: 2001 M5 Le mans
Unbalanced propshaft or faulty universal joint/propshaft coupling /guibo.
Change the "UJ" its the cheapest option
Also has the balancing been done on all four wheels??
Steve Mac
_________________
If knowledge is power,,,how brainy are my Baby`s
2001 Le Mans beast ///M5
1995 Fjord grey M5 she's a lady
2002 Black Beauty 320i Sport!!
Hey, its only wrong if you get caught
Steve Mac is offline
Old 24th October 2009, 10:25   #3
davidoli
I would certainly fit another set of standard fitment wheels to rule out any issues in that department .
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 24th October 2009, 10:26   #4
Frits
Frits's Avatar
Yeah, we tried with different wheels allready.
Well, I thought about the guibo too, but my mechanic didn't think that would be the issue. Anyway, we'll have a look at it. I just checked, and we have it on stock, it's the same as E36/46 M3
Frits is offline
Old 24th October 2009, 11:18   #5
Frits
Frits's Avatar
Allright, I just did another test drive, and I tried to let it do it again, and then push the throttle. Doesn't help, I probably just got lucky the first time.
Car is on the lift now. I checked the guibo, brand new...
Frits is offline
Old 24th October 2009, 11:27   #6
Frits
Frits's Avatar
There is some play where the driveshaft goes into the diff. At least 1 mm...
Frits is offline
Old 24th October 2009, 12:49   #7
raymondw
raymondw's Avatar
Frits,
Check the center-mount from the driveshaft. On GD55450, the rubber around the bearing was torn; due too which the propellorshaft vibrated in its enclosure with similar complaints like 'your' M5T.
Furthermore, did you torque the bolts from the front-suspension under load ? (i.e the car standing on its own wheels on a four column lift)
Raymond
==> MY90 E34 M5 3.6 <==
==> MY85 E28 M5 M88/3 <==
The E34 M5 Alps tour. Sixth edition: 14-17 September 2007
raymondw is offline
Old 24th October 2009, 14:40   #8
Ratty
Ratty's Avatar
Garage: 1991 E34 M5 Jet Black
Just a guess, but could the crankshaft harmonic balancer be *******? I know Faz had loads of trouble diagnosing a strange vibration (I think on Tonys old M5), and it turned out to be the balancer..
Testing to see if the word '*******' c-r-a-c-k-e-d gets censored again.... lol
It does lol.... must be a rude word these days
Ratty is offline
Old 24th October 2009, 15:23   #9
davidoli
Sounds obvious , but are the wheel bearings all good ?
Like Raymond , I suspect that the control arms are the most likely cause as the dampers have been replaced recently ....... were all upper and lower control arms / bushes renewed ?
Saying that , we have recently had a couple of 7 series displaying similar issues and the problem was eventually resolved by taking a bit of the play out of the steering box on the hex bolt adjustment .
However , this would suggest that the steering box has wear and will , at some point , need rebuilding / renewal .
D
davidoli is offline
Old 24th October 2009, 20:20   #10
Frits
Frits's Avatar
Originally Posted by raymondw View Post
Frits,
Well, next thing we'll do, is remove the exhaust, and have a look at the driveshaft, including the center bearing.
We noticed one engine mount (left side) is toast. Might not be the cause of the issue, but it certainly doesn't help to fix it.
Wheel bearings are OK.
Thanks for the input guys.
Frits is offline
Bad Vibrations jt2ma71 E39 M5 and E52 Z8 Discussion 3 23rd September 2009 17:51
Tubi on 07 M6 Vibrations! Andy_M6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 27th August 2009 21:33
Bad Vibrations mister2d E39 M5 and E52 Z8 Discussion 21 18th August 2009 19:56
Troubleshooting serious vibrations? wiggis E39 M5 and E52 Z8 Discussion 8 26th July 2006 02:41
Spacers = vibrations? limitup E60 M5 and E61 M5 Touring Discussion 16 19th May 2006 10:30
Page generated in 0.14307 seconds with 11 queries
