Originally Posted by Alan Archer
Firstly, does your car have servotronic fitted ? A check of the build sheet will tell you unless of course you have nurburgring suspension with which it came standard.
yes it has servotronic (Faz told me) and no EDC as it's a 3.6.
There is NO build sheet for my car (it's a South African assembled car) and despite many communications with various bits of BMW no build sheet can be found.
It only has two modes & the switch over occurs just above parking speed.
Assistance is raised at walking pace & reduced at speed to improve feel.
The servotronic unit takes a speed input to determine setting just as the car audio
wiring provides a speed signal wire for volume control.
so the servotronic is independent (sort of), ie, it is sent a speed signal - by what I wonder? also, wonder how I check operation of the device that sends the signal...
I'm pretty sure it's operating intermittently, the stereo volume speed adjustment definitely doesn't happen all the time, so if thats feeding from the same signal then that would explain a lot...
also just thought - the drivers side windscreen wiper doesn't clear well when it's cold, which is the speed / pressure mechanism, I wonder if this is also driven by the same speed signal?
further complicated by cruise control I suppose.
and finally - read the instrument cluster repair page (posted on RichardBaxters thread re cluster failure) and it's starts with this sentence "instrument cluster started to fail by having the fuel, temperature, and lower digital
readouts not working during the first 20 minutes of driving or until it warmed up" - I've had no problems this summer, but, when the weather turned colder recently the problems all came back...
