Old 21st October 2009, 23:58   #1
marekd174
Garage: 92 M5T , 85 M5
3.8 MAF rebuild
After replacing a lot of parts (vacuum lines, temp sensor, O2 sensor, plugs, coil boots, one coilpack, all filters, maf boot, valve adjustment, TB adjustment and sync) to try and get my car to stop running rich and being down on power (the parts were original to the car, so they were due for replacement) and not really fixing it and before I spend an insane $$$ on a new MAF, I decided to give Injection Labs a call and go ahead and send my MAF to them.
Just received an e-mail from Kevin, saying that my unit is ready. I'll report if this fixed my issue and how the car drives with the "new" MAF. If that doesn't fix it I will get a new O2 relay as per an earlier thread and see if that fixes it. If not I will be at a bit of a loss.
Understandably Injection Labs has not seen this MAF before (not used on an engine sold in NA, and only used on the 3.8 E34 M5), but said that Bosch only uses a few calibrations and there was some other Bosch MAF that had a similar circuit to our MAF's.
If this works out, there will be a much cheaper alternative to MAF replacement for us 3.8 guys as the rebuild was $175+shipping. Keep your fingers crossed and stay tuned folks.
marekd174 is offline
The Following 2 Users Say Thank You to marekd174 For This Useful Post:
corneredge (22nd October 2009), dscam (22nd October 2009)
Old 6th November 2009, 18:43   #2
Eku
Garage: BMW M5 3.8 -92 silver
Hello
Did you have a good luck and get your MAF fixed?? I also talked with Kevin with my 3.8 MAF, but founded used what worked.
Eku is offline
Scrap or rebuild?? ilundber E34 M5 Discussion 6 8th September 2008 12:44
SESLht caused by MAF...is it just the sensors in it or do you replace the entire MAF? 911/M5 E39 M5 and E52 Z8 Discussion 16 6th March 2008 18:55
M5 rebuild nulkki E34 M5 Discussion 6 12th July 2007 09:52
BMW MAF identical to much cheaper MG Rover MAF Salty E39 M5 and E52 Z8 Discussion 3 30th November 2005 12:20
engine rebuild durt E34 M5 Discussion 3 14th March 2003 19:45
Page generated in 0.09243 seconds with 11 queries
