Old 21st October 2009, 12:22   #1
Ruppy
Garage: ///M5 3.8 Avusblue
Send a message via MSN to Ruppy
oil separator and nonreturn valve question
Hi guys.
Does anyone know what inside the oil separator. I opened mine. It was completly empty. It is normal?
Other.
What is the right direction of the non return valves unther the butterflyes? Every butterfly have a non return valve in a idle air line. The ICV feed the idle air to the buterflyes through this valves.
This valves have 2 side one is metal and the other is plastic. No any arow or some direction signs on it.
This valves not realy 100% "non return" just one direction is easyer to go through the air the the other. I dont untherstand how does operate.
///M5 3.8 1993, 345/328 big brake
E30 327i turbo...gone but never forgotten
Ruppy is offline
Old 21st October 2009, 20:11   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
my oil separator is also empty, i believe it's supposed to be!
No idea on the other issue however.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 21st October 2009, 23:22   #3
Tomba
Garage: BMW E21 325i (M20B25 engine)(Alpine weiss)
Originally Posted by Ruppy View Post
Hi guys.
Empthy,.. There is some kind of diafragma below fastened with a hex. bolt. The oil is supposed to drain below the diafragma to the dipstick in the sump and not sucked by the engine vacuum into the cumbostion room. Use fuel or other liquid to see if it spools (use a can to pick up the fluid so it won't fluds into the engine).
If you put vacuum on 1 side and you can't get vacuum, this side belong to the throttle bodies (air should folow the direction of ICV - > Throttle body= right direction). Maybe the non return valves are there to get a more stable vacuum in the idle strip, you use them because you only want a vacuum in the throttle body and no influence of others. With the non return valve each cilinder is seperatly and not connected which each other. Synchronosation the throttle bodies would be lots better, there is less influence of the other vacuum from other cilinders. Maybe it has more to do with it. You only see them on S38B38 and S50B3X and S54B32.
To///Mba
Tomba is offline
Old 22nd October 2009, 00:42   #4
Ruppy
non return valves
Hi Tomba
I removed every valves just clean out. I am not shure the former owner removed or changed this valves.
Direction....is not an easy question because this valve is more less similay in both direction. I can look through this valves with my eyes.
Only inside the valve visible a small rubber "pin" , If i blow through (with my mouse) i can't fell difference.
The butterfly sync is realy was necessary....because my car so old and the butterflyes worn a bit. (the closing positions are missaligned) I done it carefully. Now every butterfly open in a same position, and the vacuum is setetted to in each cyl based on a description. Around -0.3bar( vacuum)
Ruppy is offline
Oil Separator Hoses...now I'm a believer! doc$holliday E39 M5 and E52 Z8 Discussion 29 13th November 2009 21:14
New Oil Separator Hoses rock! JesperT E39 M5 and E52 Z8 Discussion 21 22nd April 2009 21:14
oil separator return hose sbacchus E39 M5 and E52 Z8 Discussion 6 3rd February 2009 14:18
POLL: Oil Consumption Status after Oil Separator Replacement RUFM5 E39 M5 and E52 Z8 Discussion 1 2nd March 2008 12:18
Question on accumulator oil valve for vanos? m5 deamon E39 M5 and E52 Z8 Discussion 7 1st March 2008 23:50
Page generated in 0.10608 seconds with 11 queries
