Old 18th October 2009, 14:46   #1
richardbaxter
Instrument Failure
Driving yesterday and suddenly all the instrument needles went haywire, the mileage indicator/service indicator kept flashing on and off.
Car still runs fine but instruments are all misleading and the fuel guage needle is jammed at about 5oclock position.
Is this something simple or a new instrument cluster?
richardbaxter is offline
Old 18th October 2009, 20:19   #2
MY BUD
Garage: e34 M5 3.8 in Daytona Violet.
When my instrument cluster went it was due to the alternator failing and putting out 18 volts! However mine stopped working altogether but its probably worth checking the voltage anyway.
MIKE.
MY BUD is offline
Old 18th October 2009, 22:10   #3
davidoli
Certainly sounds like the cluster Richard ........
Have you got anybody local that would allow you to try their clocks in order to ascertain the cause ?
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 19th October 2009, 10:06   #4
farrell
farrell's Avatar
Sales Feedback: (4)
Richard.
Sounds like the battery assembly that is soldered onto the OBC circuit board inside the I/C may have leaked.
If not, pm or ring for options.
Cheers
Farrell
www.darjac-racing.co.uk
farrell is offline
Old 22nd October 2009, 06:47   #5
Montanvs
Montanvs's Avatar
Garage: 93 Avus Blue E34 M5
Not sure if it could be the capacitors on the instrument cluster circuit board. They apparently have a history of eventually failing causing symptoms like you describe. This website for the E34 shows a DIY.
http://home.comcast.net/~fongman1/repairpages/instrumentclusterrepair.html
Montanvs is offline
The Following User Says Thank You to Montanvs For This Useful Post:
davidoli (22nd October 2009)
Old 24th October 2009, 02:32   #6
richardbaxter
Thanks for replies.
After a day or two with the car parked up the constantly displayed IC caused the battery to drain right down.
I've now removed the IC and have the battery on charge - will speak with someone who maybe be able to repair the existing IC otherwise it wil be an expensive circuit board from BMW...
Old 24th October 2009, 10:41   #7
davidoli
Rich , don't go to BMW for an expensive circuit board .......nigh on a grand IIRC .....as I've got a set of 3.8 clocks here for you if you want them.
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Transmission failure or just a failure.... Rickadelic E60 M5 and E61 M5 Touring Discussion 10 5th July 2009 20:33
Instrument Pack Intermittent Failure FinalEditionE34M5 E34 M5 Discussion 9 11th February 2009 14:30
instrument gauges.. zavy E34 M5 Discussion 17 26th April 2006 11:09
Engine Failure. Reduced Power. DSC Failure BradM5 E60 M5 and E61 M5 Touring Discussion 2 19th October 2005 20:59
OBD II Failure - NYC Car Inspection Failure JAM M5 E39 M5 and E52 Z8 Discussion 9 20th May 2005 16:24
Page generated in 0.09615 seconds with 11 queries
