What type of fluid do I put into the SLS resevoir?
It's just power steering fluid, correct? My rear SLS might be leaking...probably will be getting the BavAuto SLS Delete Kit along with RDSport Bilstein's and H&R springs.
thanks...i was being lazy, popped the hood and there it was right on top of the canister.
I just hope my local auto parts store carries this stuff...
Call around first, i had no luck finding it at any of my local auto parts stores, so i picked up a liter at my dealer when i needed it.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
And a lot of people experience pump problems after using the wrong KIND of Pentosin
LHM (Citroën hydraulic fluid) is only for emergency use, but the system must be flushed afterwards and Pentosin put in there. Mercedes-Benz / ATE fluid also differs from viscosity to the Pentosin variants.
