8th September 2009, 23:34
#6
95 M5 3.8
Originally Posted by 93FIM5
Working on it currently but Im also moving the oil cooler as well so Im not sure it really applies. Why do you think you need a larger oil cooler?
because I am tunnig my engine.... it will run with a 12,7:1 compresion ratio, bigger valves, will use ethanol as fuel, diferent camshafts, doble coils etc, much higher rev limiter (about 9000 to 9300), re-worked head etc.... will produce about 400 to 450hp in the crank... an the use will be severe.
This is why.
