Old 2nd July 2009, 19:56   #1
jibbajabba
Garage: 1988 M3 S38
Who here has used 3.8 throttle bodies on their 3.6
I have the 3.8 tb's but the vacumn ports are different. Just curious what the best way to convert it is...
THanks.,!
jibbajabba is offline
Old 2nd July 2009, 20:55   #2
93FIM5
Garage: 1993 M5 Black
Pictures?
93FIM5 is offline
Old 2nd July 2009, 21:17   #3
WillM5
WillM5's Avatar
Garage: E34 M5 Diamantenschwarz
Engine : S38B36 - MM 296° Rally Intake Cam, E28 Exhaust Cam (248°), Race Port (31mm) , High Lift Valve Springs, High Performance Rings, Refreshed Bottom End, Port Matched Throttle Bodies, BMC CDA Intake
Exhaust : Wrapped Headers, Straight Exhaust, Supersprint Resonator, Eisenmann Race Exhaust
Suspension : H&R Sport Springs, Koni Yellows, M5T Rear Sway Bar, Racing King Rear Subframe Inserts
Exhaust Clip http://www.youtube.com/watch?v=I3CSE39PTCA
WillM5 is offline
Old 2nd July 2009, 21:37   #4
jibbajabba
Garage: 1988 M3 S38
Here is a 3.6 Throttle Body. Notice how it has the one large port in the middle
To the left and to the right of that there are no ports at all.
Now on the B38 3.8 Throttle Body they have a vacumn bar accumulator that runs the length of the throttle bodies, with each set of two having a little box that connects to it.
Then when you compare the other side of the throttle bodies, the 3.6 has the one port and two smaller ones above it:
The 3.8 throttle bodies do not have this on this side.
Now I have to admit, I haven't really researched this yet, nor have I even attempted to install and figure it out...which Im sure I could. Just looking to see if anyone else has done it already and can provide some input. I'm assuming the easiest way to do this, is just use all of the 3.8 hoses etc etc etc.
Cheers.
Old 2nd July 2009, 21:40   #5
jibbajabba
Garage: 1988 M3 S38
WillM5,
Im aware of the porting necessary, and I know they bolt up. What I was trying to figure out was the best way to adapt / modify the 3.6 setup to the 3.8 setup / or just use all the 3.8 vacuum hoses, ICV etc etc... Does it make sense what Im asking...because Im starting to confuse myself
Old 2nd July 2009, 21:52   #6
93FIM5
You should connect the fuel pressure regulator to the vacuum bar and the vacuum reservoir line with the check valve to the port on the number three throttle body. The IAC valve plugs into the rail as well instead of onto the cast throttle port on the 3.6. But after the vacuum reservoir you still have to use the plastic T to feed the solenoid for the air injection pump and for the resonance flap. On the 3.8 this isnt needed because it uses the ECU to control the variable resonance flap assembly.
93FIM5 is offline
Old 2nd July 2009, 21:52   #7
WillM5
WillM5's Avatar
I honestly couldnt tell you man, ive been dreaming of throwing some 50mm on my 3.6 to but i just cant convince myself to spend so much money for an extra 2mm per throttle. Ive got a 3.6 head that im gunna be developing some throttle slides on this year, custom port shaped to match the intake port and not stay round but oval to keep air velocity up .
WillM5 is offline
Old 2nd July 2009, 23:00   #8
jibbajabba
Garage: 1988 M3 S38
Awesome, that's exactly what I was looking for.
Last edited by jibbajabba; 2nd July 2009 at 23:01. Reason: because I can't spell for ****.
Old 6th July 2009, 07:53   #9
93FIM5
After re-reading my post I got a little confused when I was explaining the actuation of the resonance flap for the S38B38 it is also actuated by a vacuum solenoid its just that its switchover points are controlled by the ECU and not a separate control unit like the 3.6. None of that changes what I told you I just didn't want someone to get misinformation.
93FIM5 is offline
Old 8th July 2009, 02:23   #10
Ferrari-Bmw
Garage: Alpina B10 Biturbo Ferrari Yellow
I have seen one 3.6 w/ 50mm ITB ... the Cylender head was matched and minor rework,,
deleted torque/flap ,,,,,, custom airbox,, reworked ECU no MAF ,,
higher RPM limet
350 horsepower said the owner,,,,,,
Sveinbjörn Hrafnsson
E30 CABRIO S3 8B38
ALPINA B10 BITURBO 346 @ 507
www.123.is/alpina
Ferrari-Bmw is offline
DIY on Throttle Bodies anyone?? Finesta101 E39 M5 and E52 Z8 Discussion 45 14th July 2008 01:33
Where are the throttle bodies and how to clean jcdavis E39 M5 and E52 Z8 Discussion 17 14th January 2008 19:56
FS: E34 M5 3.8 throttle bodies 50 mm adwo For Sale or Wanted 0 14th March 2007 19:49
WTB: S62 Throttle Bodies M3Bmwcoupe For Sale or Wanted 1 27th June 2005 11:11
8 Throttle bodies vs Dual Throttle bodies, Dinan Myth? MIB E39 M5 and E52 Z8 Discussion 6 26th December 2003 17:33
Page generated in 0.15724 seconds with 11 queries
