Old 29th June 2009, 15:49   #1
DaveW
Garage: Alpina B10 Bi-Turbo in Macau Blue
Electric Cooling Fan Failed...
Having just read a similar post on ditching the viscous fan in favour of an all electric solution, my thread seems to be quite timely.
Having noticed an increase in Viscous Fan noise and reduced output from the A/C on my Bi-Turbo - a little investigation revealed a stone had wedged itself behind one of the blades of the electric cooling fan preventing it from turning.
With stone removed, fan won't run - no fuses in the engine bay box appear to be blown so anyone got any ideas? Do the motors burn out quickly or would the high and low speed relays suffer first? Or perhaps I've not found the right fuse location...
All help greatfully received!
Thanks,
Dave.
DaveW is offline
Old 29th June 2009, 16:42   #2
1day
Garage: E34 M5 1991 white
depends how much current the fan was allowed to draw before the fuse kicked in.
if the rating of the relay / fuse is close to the max rating of the fan then the chances are the fan motor will have burned a "ditch" in the electric coil surface (like a flat spot in a tyre).
if all else fails then try power the fan directly from a spare battery? (although I'm no auto electrician, I've seen it done).
If it's thermostatically controlled, it could also be a temp sensing problem?
1day is offline
Old 29th June 2009, 17:23   #3
DaveW
The only diagnostic I've successfully completed is to prove the radiator thermo switch is working, so sadly it's not that.
The fragile fan coil theory might well be right - I'll bridge the relay outputs to see if it does jump into life before I tear the whole front end down to get at the fan. Anyone know of a replacement in any shed/garage anywhere?
Thanks,
Dave.
DaveW is offline
Old 29th June 2009, 21:33   #4
davidoli
What's the part number Dave ? I'm sure I've got one ......
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 29th June 2009, 21:56   #5
DaveW
Hi Dave,
Well, if you trust Real OEM to get it right first time, the part number is 64541392913 listed at a whopping $595! but to find out for sure I'll have to take it off. It has curved blades if that helps?
Thanks,
Dave.
DaveW is offline
Old 29th June 2009, 23:28   #6
davidoli
Don't worry Dave , I'm sure that I've got one .
£20 + £10 p&p ......sound fair ?
D
91 Sebring 3.6
E28 UK RHD M5
davidoli is offline
Old 30th June 2009, 00:32   #7
DaveW
Blimey, more than fair - I'll take it!
PM to follow with my address details.
Thanks,
Dave
DaveW is offline
Old 30th June 2009, 00:50   #8
M5 GOR
Garage: `95 LE Rosso Red
If the fan was jammed it is possible that you have burnt out the low speed resistor as all the current goes through that at low speed and by-passes it at high speed. If you can "short" out the switch on the side of the radiator to bring on the fan at full speed it should show you if it's the fan or the resistor.
I've found that the resistor sometimes can go before the fuse does so it kinda sends you off in the wrong direction!
M5 GOR is offline
Old 10th November 2009, 17:16   #9
Baddie
Garage: M5 Daytona Violet 3.8
Testing auxiliary fan
Gentlemen, a question if I may...
How do I test the operation of the electric fan? I would like to jump the contacts of the three pin plug on the temperature sensor on the right hand side of the radiator, but don't know which ones of the three to connect to a 12V supply. I have done a search and confirmed that this is an appropriate test, but could find no data on the correct pins to jump and my copy of the manual does not have an appropriate wiring diagram.
I have recently replaced the electric fan, but until this week my viscous fan clutch was tired and the viscous fan was doing producing a lot of airflow so it was hard to know if the electric fan was not working because of this or because of an electrical fault - I have done a preliminary check of wiring, fuses and plugs. Now I have replaced the fan clutch (a massive improvement in noise levels and apparent engine effort at all speeds) the ambient temperature has also dropped. My car does not currently have working aircon to trip the cooling circuit that way.
Thanks for your esteemed help.
Anwar
If you focus on quality, you don't need to worry about quantity.
Baddie is online now
Old 11th November 2009, 00:34   #10
AliveM5
Garage: 1991 3.6 Mauritius Blue
Here's the wiring diagram I used a while back to do the same thing. Turn on the ignition and you will get 12v at two of the pins (assuming your fuses are ok of course) whilst one remains at ground. Shorting the relevant 12v pin to the ground pin will give you fast/slow.
AliveM5 is offline
The Following User Says Thank You to AliveM5 For This Useful Post:
Baddie (11th November 2009)
Cooling fan fell off and cooling fan clutch HDClown E39 M5 and E52 Z8 Discussion 12 14th July 2009 07:17
electric cooling fan roortube E34 M5 Discussion 10 6th July 2009 20:43
How loud is your cooling fan? bimmernut1 E39 M5 and E52 Z8 Discussion 37 26th October 2008 09:48
Brake Cooling Kit BMWM5Driver For Sale or Wanted 2 18th October 2004 07:27
electric cooling fan Yves E34 M5 Discussion 0 23rd April 2000 01:07
Page generated in 0.12322 seconds with 12 queries
