Old 28th June 2009, 20:10   #1
First e28 M5
Garage: E28 M5
S38-b36 cam gear upgrade question thanks
Hi 3.6 guys,
What is the best exhaust Cam gear upgrade for S38-B36. I have heard/sure that Dinan uses 3.8 cam gear. Frank Fehey uses S14 Evo Cam gear ??
Which of the two choices are the best ?
Also do I lose hi end power if yes with which one?
Opinion is needed.
Anri
First e28 M5 is offline
Old 28th June 2009, 20:46   #2
roortube
Garage: 1991 Dinan M5, black; 1993 s4/rs2; 1969 Lotus Elan +2S130
I just installed the Dinan gears and chip, and I'm a fan. Coming from an EAT chip and stock gears, I can't say as I can feel any top end power loss, but it feels like there's loads more torque in the mid range. This makes the engine feel a bit less peaky. The 4k spike in power is still there, but you don't notice it quite as much because of the torque increase. I have yet to put it back on the dyno to measure the changes, but that'll be a moot point anyway since conditions will have changed. I can tell you that 0-60 and 0-100 times have decreased, and there's a bit less need to down shift to pass when cruising at 60-70mph in 5th.
roortube is offline
Old 28th June 2009, 23:15   #3
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
this is the first i've heard about using the s14 cam gear. I guess my question would be is there a difference between the s38b38 and s14 evo cam gear?
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 28th June 2009, 23:26   #4
dkl2001
Garage: 93 M5 3.6, Calypso Red
Are all the Dinan chips coded for the cam gear upgrade? I have a Dinan chip that came with the car and I'd like to do the cam gear swap, but I'm not 100% sure I have the right chip (if there is a "correct" Dinan chip). Any thoughts?
dkl2001 is offline
Old 29th June 2009, 05:25   #5
roortube
they're the same
roortube is offline
The Following User Says Thank You to roortube For This Useful Post:
dkl2001 (29th June 2009)
Old 29th June 2009, 23:01   #6
dkl2001
Do you think this upgrade hurts the "longevity" of the engine?
dkl2001 is offline
Old 29th June 2009, 23:46   #7
daytonaM5
Garage: E34 M5 3.8L daytona violet / E46 M3 Grey
If you want top end power, decrease overlap.
If you want low-mid engine speed power increase overlap.
So you have a trade off.
This is why E36/E46 M3 came with vanos and you had the best of both worlds.
So what do you want?
E34 M5_respray_twin_turbo (under surgery)
E46 M3_Jet Black_941 whp Dyno Dynamics
E36 M3 Evo Fashionred_twin_turbo
daytonaM5 is offline
Old 30th June 2009, 21:14   #8
First e28 M5
Garage: E28 M5
Cam gear upgrade
Well since the S38 Engine family is made to move with wider torque band vs S14. Seems like I will use the EVO E30 M3 cam gear with A100 because S14 is made to be high end power versus 3.8 cam gear A105 or A110.
I want to upgrade on my S38-B36 and S38-B35
So far I am on theory but I need somebody that has done the upgrade and give opinion.
Anri
Old 1st July 2009, 01:07   #9
dkl2001
What are your planned uses for the car? I want to do it because mine is a daily driver and I could use the added torque for my around town driving. I highly doubt I'd ever top the car out anyway.
dkl2001 is offline
Old 1st July 2009, 02:03   #10
First e28 M5
Garage: E28 M5
Cam Gear
Well, I never take my E24 M6 and S38-B36 to trak day so its all daily driving. But I do lots of rolling races with my frineds who has all bmw m-cars and that is what I need.
Now I have only Dinan chip and will add M88/3 Euro Headers. So far I am happy with the Torque/Power band in town.
But say when I do some pulls from rolling start my rpm band is between 4500rpm and all the way to 7000rpm.
So that is all I need to know wich one will give me more juice at high end without hearting the low end torque that much?
A
3.62 Diff Gear Upgrade using E46 M3 Ring and Pinion RUFM5 E39 M5 and E52 Z8 Discussion 55 24th January 2008 19:25
Speedometer Calibration After a Differential Gear Upgrade RUFM5 E39 M5 and E52 Z8 Discussion 3 6th September 2007 04:44
gear box question dalius E34 M5 Discussion 3 9th May 2006 00:08
Question on First to Second Gear rob1 E60 M5 and E61 M5 Touring Discussion 3 16th January 2006 16:31
question on topgear/fifth gear ycchan Off Topic Forum 3 15th November 2004 22:23
Page generated in 0.15574 seconds with 11 queries
