Old 26th June 2009, 20:08   #1
keviha
keviha's Avatar
Garage: 1993 Alpine White M5
Likely Caust of Anti Lock Warning Light?
First, let me say I tried the search function but couldn't locate specific details. My anti-lock light came on this morning, what is the likely cause given age of the car? Just my luck, it comes on right after I spent over $2,000 on cooling related parts.
Thanks. Kevin
keviha is offline
Old 26th June 2009, 20:50   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i believe a dealer or shop with a gt1 can pull a fault code that will point you in the right direction. I'd first do a visual check of the abs pulse generators, the front's i know mount into the hub, behind the front brake disc.
I recently did my struts, and had to remove and reinstall these and they can get quite dirty, perhaps a clean and wiring check would solve the problem. They're magnetic so you'll find all sorts of little fragments stuck to them.
I think the gt1 can tell you which one is causing the problem, if that is the source.
I'd imagine the rears are installed in a similar fashion, but i've not had my hands on them.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 26th June 2009, 21:01   #3
kiudog
kiudog's Avatar
Garage: M5 cosmic black
Mine has the same problem. The diagnosis first was sensors, i changed them and the light was still on. Then, went through the diagnosis again and one of the valves on the ABS pump is shot.... do your light comes on after a while you start the car? Do you feel the brake pedal vibrating a little and then it stops vibrating and the light comes on? This is whatŽs happening to mine. the AB pump is part # 34511157874....i found one second hand and will try it on....
KiuDog - mmm crazy
1995 E34///M5
2008 VOLVO C30 2.0
1994 XL 1200
1999 1340 FAT BOY
2005 HERITAGE SOFTAIL
2005 DEUCE
2006 ELECTRA GLIDE
I rideŽem like I stoleŽem!
kiudog is offline
Old 26th June 2009, 21:11   #4
keviha
keviha's Avatar
I changed the sensors along with discs and pad's less than 15,000 miles ago. I suppose one of them could have failed. I have plenty of disc/pad available. I don't track car...drive it sparingly (under 20 miles day)...though most is city driving. In any case, I do have a fault code reader that I use to reset the oil light indicators when I change oil/filter. I can't recall if it reads other faults.
This is the first time it's come on...and it stayed on all the way to work. I noticed no change in brake pedal pressure, vibration, etc. Maybe I'll be lucky enough and it will be sensor and not the ABS pump.
Thanks, guys. Kevin
keviha is offline
Old 28th June 2009, 05:12   #5
roortube
Garage: 1991 Dinan M5, black; 1993 s4/rs2; 1969 Lotus Elan +2S130
Did you change the abs pulse generator sensors or the pad wear sensors? A GT1 isn't necessarily needed and is very expensive. Peake Research has an abs specific tool that's only a bit over $100. Well worth it as a shop with a GT1 will likely charge you nearly the same for one diagnosis. If you feel no change in the pedal feel it's likely a sensor issue (faulty/dirty sensor, dirty exciter ring, bad wire or connector). As suggested before, do a visual inspection of the wire leads and connectors, then remove and clean them. If that fails, pick up the Peake tool and scan for ABS related codes.
roortube is offline
Old 28th June 2009, 05:25   #6
keviha
keviha's Avatar
I changed the pad wear sensors when I replaced rotors/pads. The light hasn't come back on and I never did notice a change in the pedal feel, so it would seem the ABS sensors are the likely culprit. Are they difficult to replace?? Thanks. Kevin
keviha is offline
Old 28th June 2009, 07:37   #7
mottati
mottati's Avatar
no one 5mm bolt, iirc and it comes out. It's on the back side of the hub.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 30th June 2009, 22:53   #8
M5 powered
Garage: M5 limited edition (02/50) Rosso Red
If it turns out to be the ABS pump, dont go to the stealers. I have a good spare one.
Had an issue which turned out to be a Master Cylinder problem. Ugh....
Best
Jonathan
1995 M5 Limited Edition (02/50)Rosso Red
Pilot Sport 2 Rubber
Valentine One With Conceal
Twin Head LRC100 IR Jammer System
Origin Blue B2 GPS
M5 powered is offline
Beginning of the end? DCS warning light...ABS warning light....Radio off.... Kleintje E39 M5 and E52 Z8 Discussion 5 18th November 2008 09:35
Anti-Theft Alarm goes on when I lock the doors and leave it for few minutes! wyvern E39 M5 and E52 Z8 Discussion 10 14th September 2008 05:04
Driver seat crease and peoblem with steering wheel lock warning fanm5 E60 M5 and E61 M5 Touring Discussion 6 23rd May 2008 01:50
Check light warning / Light ECU programmable? whatheheck E39 M5 and E52 Z8 Discussion 4 9th March 2007 21:22
Air bag warning light rich E34 M5 Discussion 2 27th August 2003 02:50
Page generated in 0.13523 seconds with 11 queries
