Old 26th June 2009, 12:21   #1
omar510
Garage: e34 m5 Sonderlack
1991 e34 M5 Relay Layout Picture requested
Hey guys the previous owner of my e34 m5 stripped out all the relays in the e-box and now iI am having the worst time trying to find the correct relays and their original positions. Can any 91 e34 m5 owners post a picture of their fuse box and relay positions? Thanks!
omar510 is offline
Old 26th June 2009, 18:01   #2
unesential
Garage: 1991 M5 black
Send a message via AIM to unesential
try this
unesential is offline
Old 26th June 2009, 18:29   #3
omar510
hey thanks for that picture. I was able to find that earlier today but unfortunatly it doesnt have a part number or colors for the relays. I think my best bet would be if someone here took a look at their own and read off part numbers and colors. Thanks again
omar510 is offline
Old 28th June 2009, 03:45   #4
omar510
anyone else?? This is turning out to be a major headache
omar510 is offline
Old 28th June 2009, 05:01   #5
roortube
Garage: 1991 Dinan M5, black; 1993 s4/rs2; 1969 Lotus Elan +2S130
would some high res photos due for you? if so I'll try to snap some tomorrow after work.
roortube is offline
Old 28th June 2009, 05:04   #6
omar510
yah that would be awesome! I am willing to try anything. thanks!
omar510 is offline
Old 28th June 2009, 05:13   #7
roortube
which box are you referring to? located under the hood near the fire wall on the drivers side?
roortube is offline
Old 28th June 2009, 05:36   #8
omar510
Yah I'm missing the relays from there
omar510 is offline
Old 28th June 2009, 10:24   #9
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
if you don't get any info here, i'll have my car at roger krauss in castro valley on monday afternoon getting corner balanced and aligned, you can look at my relay box and take some pics.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 28th June 2009, 20:58   #10
roortube
Here's a pic of the general layout of the box. I tried to snap the part numbers, but they didn't come out. Lemme know which numbers you need and I'll post them up for you.
roortube is offline
DME Fault 35 - Electronic Fan (Relay) - Auxiliary Fan Relay Not Working SleeperE39 E39 M5 and E52 Z8 Discussion 19 9th August 2009 23:04
New Layout Stevie E34 M5 Discussion 2 24th January 2006 02:02
My 1991 Mauritius Blue - picture AliveM5 E34 M5 Discussion 12 26th December 2005 19:02
RHD Vs LHD Layout diffs m5-black E60 M5 and E61 M5 Touring Discussion 8 5th September 2005 17:54
Page generated in 0.13191 seconds with 12 queries
